Rear end driveshaft bearing??
Old Mar 30, 2007 | 01:05 PM
deserttoy84's Avatar
What is it called? Its the bearings in the rear end where there driveshaft connect. Is it a pinion bearing? im not talking about the center bearing in a two piece driveshaft, i have a one piece drive shaft. Are there any links on how to replace this? mine is worn out. I have play going into the rear end when i move the driveshaft around. Is it even possible to replace witout tearing apart my rear end?
Old Mar 30, 2007 | 01:15 PM
4Crawler's Avatar
At the rear axle, that is the pinion bearing. Try tightening the nut up first:
- http://www.4crawler.com/4x4/CheapTri...eal/index.html
Old Mar 30, 2007 | 01:25 PM
Thanks!!!
Old Mar 30, 2007 | 02:14 PM
SO far so good. I tightened it up(it was loose) and no more ping when i take off. I bought new u joint though just because im sure there old so ill gonna take off the drive shaft again tommarow to do those. THanks again for the help!
Old Mar 30, 2007 | 06:22 PM
titicaca's Avatar
stupid crush sleeves....
Old Mar 30, 2007 | 07:22 PM
huh... i read on like 4x4 wire you preload that nut to like 20in pounds or somthing. Why is it supposed to be 90ft lbs?
Old Mar 30, 2007 | 07:29 PM
4Crawler's Avatar
Pre-load is defined as how much torque it takes to turn the pinion shaft in the bearings. That is set by either crushing the crush sleeve or with shims and a solid spacer, basically sets the distance between the two pinion bearings, less space = more pressure/pre-load on the bearings = harder to turn.
The torque on the pinion nut is what holds the flange to the pinion shaft. It should be approx. 90 ft-lb. Torques upwards of 130 ft-lb is used to crush the crush sleeve and alter the bearing pre-load. So you need tight enough to stop the flange from loosening, but not too tight so as to change the bearing pre-load.
Old Mar 30, 2007 | 10:27 PM
ahhh... thanks for clearings that up!
the1998sr5
15
Jul 14, 2020 08:35 PM
jerusry
Oct 19, 2015 05:28 PM
Daneums
Aug 20, 2015 05:36 AM
hangtown88toy
Jul 10, 2015 02:33 PM
akaphilly
Jul 9, 2015 02:18 PM
