Rear Drum Brakes, 84 SR5, 4WD
Old Feb 4, 2020 | 02:21 PM
DAYLEY/CHALLENGER's Avatar
5 Year Member
Hello guys..........changing the shoes on the truck and on the drivers side, the wire cable that does the self adjusting when backing up, was almost frayed into. I have looked all over and found none. Any ideas of a source. Thanks, David.
Old Feb 4, 2020 | 05:20 PM
akwheeler's Avatar
If you look for a parking brake cable you might have better luck, the self adjusting is just a side effect.
Old Feb 16, 2020 | 06:18 PM
5 Year Member
Ok, what I ended up doing as I could not find a direct replacement, I ordered two from NAPA that were a little longer, pried open the crimp on the loop end, repositioned the wire to make them the same length of the old ones recrimped and then installed. Worked fine. Less than $10.
IdleIvey
Oct 20, 2019 01:56 PM
toyospearo
Aug 3, 2011 01:47 PM
live4soccer7
Nov 10, 2010 11:13 PM
titicaca
Oct 18, 2006 08:19 PM
Gangus2006
Nov 5, 2005 07:26 PM
