Rear driveshaft interchangability?
Old Jan 30, 2007 | 07:05 PM
EFB16ACRX's Avatar
Hi all, I was out wheeling my 88 4x4 extra cab truck last weekend, and got the drive shaft hung up on a rock. Didnt mess it up TOO bad, but its to the point where it vibrates and id like to pick up a new one. AFter searching i coudlnt find any info, so, when im at the junkyard what years can i pull shafts out of? its a 22re 5 speed if that helps any.
Old Jan 30, 2007 | 07:52 PM
myyota's Avatar
Need to know what year truck you have ?...
Old Jan 30, 2007 | 07:57 PM
EFB16ACRX's Avatar
i said in my post its an 88, but since im a dumbass and put it in the wrong section, so i guess it doesnt matter anyways.
Old Jan 30, 2007 | 08:16 PM
4Crawler's Avatar
'84-'88 Xcab or long bed pickup should work, given the same setup as yours. If you have the 2-piece with center bearing, get one like that. Try http://www.car-part.com/. Of find a local driveshaft shop and have yours re-tubes with heavier wall tubing.
Old Jan 30, 2007 | 08:40 PM
MudHippy's Avatar
HEY!!!!!! That car-part.com's a secret! Your makin' this too easy now! Just replaced my 88's shaft from them recently, VERY CHEAP, too. $150
Old Jan 31, 2007 | 05:38 PM
titicaca's Avatar
not as cheap as my square front shaft. 150 for a front shaft is rediculous. you could get your rear shaft retubed and rockwell ballanced for that much.
gillesdetrail
Aug 3, 2015 04:43 PM
kirkrunner
Jul 27, 2015 07:59 PM
TDonkey
Jul 26, 2015 10:14 AM
Iceman4193
Jul 15, 2015 04:48 PM
icentropy
Jul 14, 2015 10:23 AM
