Raditor leak
Raditor leak
I have a 85 4Runner that does not over heat, but pushes a quart of water out of the over flow every time I fill it up. If I do not add water every day in about a week it will not have enough fluid and will overheat. There is no water in the oil (On the dip stick).But the oil fill cap shows signs of water. I have a new radiator cap and a new thermostat. What do you guys think?
Are there also bubbles coming out of your overflow hose even after you stop the engine? My never overheated 92 4runner did the losing coolant thing before it started to burn coolant and had very visible bubbles in the overflow tank. One engnbuilder full gasket kit (primarily for head gaskets) and many little coolant hoses later it stopped.
If you oil filler cap is showing signs of coolant leak (white foam/emulsion), then you most likely have a failing head gasket. Suggest draining your oil and looking at it closely to see if you see white streaks or cloudy grayish tint. Can you see any obvious wet marks on the block along the head gasket?
I sort of felt it was a head gasket, it had a blown one when I bought it. I took a bastard mill file to the deck and head. It has been a year and 1/2 sence the repair. But it runs so good. I have 31's and I can use 5th gear on the freway all the time.
I can not see the gasket, but taking the oil out and looking at it will help The way it pushes out the water it is like there is pressure building in the coolant system.
If there is water where the oil cap it it could also be a cracked head... Make sure when you take it all apart again to have the head checked for warpage and for cracks. Sometimes the cracks aren't apparent until it is heated.
he's gone
7
Dec 3, 2019 07:08 AM
itzmywife's
Jul 25, 2015 04:55 PM
Avenged
Jul 9, 2015 07:55 AM
