quick question about white in exhaust ports
Old Aug 25, 2010 | 06:37 PM
live4soccer7's Avatar
I've got a motor and was looking at the exhaust ports after taking the exhaust header/manifold off and you can see inside the ports that there is white inside instead of being completely black (still black in there as well). Does this mean I'm burning coolant?
Old Aug 25, 2010 | 07:03 PM
myyota's Avatar
I doubt your burning coolant, if you were you would also notice the coolant level in the radiator getting low. It could mean that your running lean, you would need to look at the spark plugs to see what`s going on.
Old Aug 25, 2010 | 11:14 PM
I think you were apart of the other thread I had about building up the 22r. I had found a 22r/20hybrid on craigslist that was rebuilt 10k ago and after getting it home and cleaning it this is something I found/noticed. With that said, I don't know anything about the coolant level. The guy said he hadn't had any problems with the engine. I'll pull the plugs tomorrow and see how they look.
Old Aug 26, 2010 | 05:57 PM
Dannyboy0818's Avatar
Can we have a few more details on what kind of motor? 22r? 22re? year?
Old Aug 26, 2010 | 06:12 PM
22r early model
20r head
had exhaust header on it
weber carb
270's cam (not sure on which one specifically)
dual row chain setup
Not sure on the valves
bored .040" over
rebuilt about 10k ago
The motor doesn't leak fluids externally
I know it'll be pretty obvious once I get the motor into the engine, but if I could find such a problem while it's on the stand then it would be way easier to fix it sitting outside of the truck.
I think you know about as much about the motor as myself
Old Aug 29, 2010 | 12:52 AM
Ok, so i finally got around to pulling the plugs today. 1,2 and 4 are chocolate brown and 3 is black. Not quite sure what that means, but I will do a google search. I also pulled the oil pan today and the thing looks super clean from the bottom side and the oil was the color it should be so if it were burning coolant I would assume it would have gotten into the oil through the piston rings when the rig was sitting there. Just not quite sure on the black plug in cylinder 3.
edit: I went and googled it and it seems that a darker colored plug could mean I'm running too rich, which could very well be a possibility with the weber carb. on there and no fuel regulator. The reg. is on my list of items to get, so that may fix the problem there.
Old Aug 30, 2010 | 11:31 PM
myyota's Avatar
You are definatly running rich, a regulator will probably help, but if it doesn`t then you might have to jet the carb a little bit leaner.
Old Aug 31, 2010 | 10:03 AM
Thanks for the info. I will be getting the holley reg once I get the engine put in my truck.
tj884Rdlx
Aug 28, 2015 12:04 PM
Poppie51
Jul 23, 2015 05:03 PM
icentropy
Jul 14, 2015 10:23 AM
Coreyr384
Jul 10, 2015 11:13 AM
