Questions regarding a 1.5in shackle lift on my 84 4wd p/u
Old Dec 11, 2008 | 02:17 PM
pedrokepdos's Avatar
Hey everyone I have a 84 Toyota Pickup 4wd 5spd diesel and I am planning on adding a 1.5 in shackle lift only in the rear. As with most Toyotas the rear end sags and it doesnt help having 31" tires all around on a stock suspension either. Anyways I chose this route for ease of installation and just to prevent my tires from damaging the wheel well.
My questions are:
Other then the install, what else do I need?
ie longer shocks etc.
Could this possibly damage my driveshaft or anything else?
I dont plan on doing much off roading with this truck. It is more of my daily driver and hauler when I need it.
Any answers/advice is greatly appreciated!
Old Dec 11, 2008 | 02:26 PM
stagger_lee's Avatar
You are only going to see about 1" of lift, so shocks are fine and driveshaft is fine. Your good. I would look at getting new shocks and maybe an add-a-leaf to bring the ass end up a bit. With just shackles you still have a warn out suspension, just propping it up a bit, like a crutch.
Old Dec 12, 2008 | 12:22 AM
abecedarian's Avatar
in general, you'll only see about 1/2 of the extra shackle length added to your lift. So a 1.5" longer than stock shackle adds about 3/4" of lift if the shackle is at 45 degrees.
if you're looking to compensate for a sagging rear, my first suggestion is replacing the springs. Add-a-leafs would be my next suggestion... then extending the rear shackles would be the last option.
Old Dec 12, 2008 | 09:30 AM
I wasn't sure if he knew that and was adding 1.5" of shackle or 3"s or what. As always I agree with Abe.
Old Dec 12, 2008 | 09:56 AM
4Crawler's Avatar
You may need to shim the rear axle to correct the pinion angle change caused by the longer shackles:
- http://www.4crawler.com/4x4/ForSale/...es.shtml#FAQ12
- http://www.4crawler.com/4x4/ForSale/Shims.shtml#FAQ1
Old Dec 12, 2008 | 12:24 PM
So you guys are saying that the claimed 1.5" lift is actually going to be 1/2"? What a bunch of crap. Who the hell would waste their money for 1/2"? If I knew this I would never have bought them...
Old Dec 12, 2008 | 12:34 PM
4Crawler's Avatar
Best to measure the center-center length and compare that to stock (~3.5"). Shackle lift vs. length explained below:
- http://www.4crawler.com/4x4/ForSale/Shackles.shtml#FAQ4
So if the shackles are 5" c-c, then you'll see about 3/4" lift, if they are ~6.5" (3" over stock) then you'll see about 1.5" lift.
Old Dec 16, 2008 | 06:40 AM
Ok, so I got the shackles yesterday and they are 3" longer then stock from center of pin to center of pin. I think I am definitely going to need them for a roadtrip I am starting on soon. I will have a few people in my truck as well as over 500lb in the bed. Seeing as how it will be a long roadtrip (CO-NY and back) I dont want to run into any problems with my truck. Since it is 3" longer then stock I will probably need shims. Where can I get these and what size should I get? Could I put off getting longer shocks for a bit?
Old Dec 16, 2008 | 07:15 AM
4Crawler's Avatar
General rule of thumb is 1 degree per extra inch of shackle length:
Or best to measure the angle change before and after installing the shackles (simple tape measure technique works fine):
- http://www.4crawler.com/4x4/CheapTri...n-Measurements
And typically 4.75" long and either 2" wide or if you prefer 2-3/8" wide on the shim size:
Flying91
45
Apr 11, 2024 04:39 PM
coffey50
Jul 28, 2015 10:55 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
Coreyr384
Jul 10, 2015 11:13 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
