Project Centercap
Old Aug 24, 2012 | 07:55 PM
84YotaBuck's Avatar
Project Centercap
So, I've had these centercaps that came with my truck when I bought it off of my brother. Truck was Bone stock years ago, with the silver 15x7 silver rims and Toyota centercaps in back and silver covers to go over the hubs up front
Thought it would look cool to be able to put the rear center caps on but with my black steel rock crawler rims they won't work. Center hole is slightly smaller as well as the rims are slightly thinner. So here's what I'm attempting.
First I had to cut off the little grippers that would normally hold it on.
Next, I drilled 3 holes in the centercaps so I could bolt some tabs that I cut out with my plasma cutter to the inside of the center cap.
Next I'm going to pull a rim off, fit the cap to the center hole, tack the tabs to the rim then finish weld them on. But that'll have to be later this weekend since I'm working some OT tomorrow, be late Saturday or Sunday.
Old Aug 24, 2012 | 07:58 PM
85TurboRunner's Avatar
Don't weld on your wheels, especially with the tires on them.
http://www.youtube.com/watch?v=pNZ4siYGkag
Old Aug 25, 2012 | 04:07 AM
84YotaBuck's Avatar
Thanks for the concern, but with the minor amount of welding it's going to take, basically just spot welds, I think I'll be ok. I'll deflate the tires out of an abundance of caution, but with just doing spot welds at the center of the rim not too concerned.
Old Aug 25, 2012 | 06:23 PM
84YotaBuck's Avatar
Got one side done, working on the other side now, but here's what it looks like. I think it looks great, just a little touch of Toyota retro.
Here's the backside of the wheel after welding and grinding flush.
The front side with the 3 tabs for the cap to screw onto.
Old Aug 25, 2012 | 06:49 PM
BigBluePile's Avatar
Cool!
Old Aug 26, 2012 | 05:56 AM
bcumbie's Avatar
Looks good!
Old Aug 26, 2012 | 03:30 PM
myyota's Avatar
With those tabs welded on there you will never be able to have your tires balanced again.
Old Aug 26, 2012 | 04:13 PM
Stu Pidasso's Avatar
even though the tabs are basicly on the center of the axis? Not being a smart@ss, I am just really surprised.
83yotastockR
11
Nov 10, 2015 06:54 AM
tylermx71
Sep 29, 2015 08:49 PM
Toys4parts
Sep 26, 2015 01:56 PM
toyotasaurus
Sep 24, 2015 03:30 PM
justdifferentials
Sep 5, 2015 06:52 PM
