is it possible i've lost L4?
Old Sep 21, 2007 | 12:06 PM
4Crawler's Avatar
Originally Posted by sometoyotaguy
Could that be in issue with the Synchros? I'll try that with my 89, although it does seem to go into gear, but it seems more like 4-HI than 4-low
No syncromesh in the t-case. That is why it is tricky to shift while moving.
Usually no need to clutch in while shifting 2H<->4H. Best if stopped to shift between 4H<->4L, either in neutral or with clutch in w/ engine running.
Old Sep 21, 2007 | 02:14 PM
deserttoy84's Avatar
Try rolling slowly backwards or foward slowly as try engaging 4low. might be easier to learn how to use the 4h and 4l feature without the hubs locked. All the means is the tranfers case will send power to the front axle but wont send the power to the front wheels so it can make it easier to play with the transfer case
Sam hain
19
Sep 30, 2015 08:25 AM
voiddweller
Sep 28, 2015 11:21 PM
Scotttekoch
Sep 28, 2015 10:30 PM
JPV
Sep 28, 2015 03:15 PM
Kylenicoll33
Sep 24, 2015 12:13 AM
