ping or valves help please
Old Aug 20, 2014 | 06:59 PM
puddlepirate's Avatar
Ok I haveMy 85 toyota pickup 4x4 with the 22rec . I bought it with new everything engine tranny the works ... I was worried it was pinging Because under load like acceleration or starting off in first I would hear a ticking or clacking sound. The motor runs extremely quiet even for a 22re and the sound it's making isn't intermittent it's constant like the valve sound would be just a littler louder then when the engine picks up some mechanical advantage it goes away. I haven't had it do it up hills or anything and I owned a 92 toyota 22re that did ping and it was an intermittent audible "ping" sound like if u wack two wrenches together and it did that pulling hills till I downshift. I'm just worries is it pinging i hear or can i put my worries to rest? It's not chain slap there's only 1000 miles on the engine and it sounds nothing like my 92's ping. Oh and I've ran 87 and 92 octane no change to the noise and even retarded the timing
Old Aug 20, 2014 | 07:24 PM
millball's Avatar
Get out yer combination wrenches and feeler gauges and give it a valve adjustment.
A relatively easy and completely cost free operation.
If that does'nt correct it, at least you'll have the comfort of knowing what your valve lash actually is, rather than relying on who knows whos' work, and you can then move on to other possible reasons for your noise.
Old Aug 20, 2014 | 07:34 PM
The timing is set I didn't have the engine installed I did it haha and yes the valves could be looked at I spose
Old Aug 20, 2014 | 07:40 PM
Old Aug 20, 2014 | 07:42 PM
millball's Avatar
Sorry, your original post appeared to say that the truck had come to you with these rebuilt components installed.
Old Aug 20, 2014 | 09:37 PM
Oh no I apologize I was just hoping to figure out if the sound I was hearing was pinging ? The ticking clacking valve sound it's constant and not intermittent like any pinging I've heard before or metallic like pinging. Just curious if it's normal valve train noise . Funny thing is I'm great with these engines but I've never heard a new one run haha
Old Aug 20, 2014 | 09:51 PM
Ok I think I may have found some info and that it may possibly be the injectors which makes sense it's a dull sound and ticks in "time" and by that I mean increases with engine speed but only does it under acceleration or trying to start off in 1st gear
LotOMiles
Sep 14, 2015 11:45 PM
ac7822
Sep 11, 2015 08:49 AM
Boomer8404
Sep 10, 2015 09:01 AM
idadan208
Sep 7, 2015 09:06 AM
