Payload specs?
Old Oct 16, 2012 | 06:55 AM
wes1977's Avatar
Payload specs?
I'm trying to find out what the payloads are for the 1/2 ton and 1 ton trucks. I've got an 84 pickup 22r, 1/2 ton long bed but can't seem to come up with the specs for it. And what is the diffrence in the 1/2 ton and 1 ton? Is it just the springs?
Old Oct 16, 2012 | 08:00 AM
MudHippy's Avatar
The payload for all 1984 trucks, except ¾ ton(no 1 ton in 84), is 1400lbs. ¾ ton payload is 1800lbs. See the sales brochure found here.
The difference between ½ ton and ¾ or 1 ton is a larger differential and thicker axle shafts...usually(esp. if it's 2WD, since 4WD already have larger differentials and thicker axle shafts the same as ¾ or 1 ton). I'm not sure about the differences regarding the springs, but I'd assume there are some.
Old Nov 1, 2012 | 04:10 PM
Pat8942's Avatar
If you look on the door you will see the GVWR, subtract the curb weight of the vehicle from that, and the answer will be the load capacity
kawazx636
Oct 6, 2021 03:03 PM
83yotastockR
11
Nov 10, 2015 06:54 AM
Dale Johnston
11
Oct 31, 2015 10:22 PM
Obmi
Oct 4, 2015 11:30 AM
dbollier123
Sep 29, 2015 05:23 PM
