Out of coolant with no leaks!
Hey guys i got an 84, I did a total radiator flush and went ahead and replaced the thermostat. I parked the truck on a curb and burped my cooling system as well to make sure there wasnt any air in the system. However when burping the system my thermostat failed open. Afew days later it closed. but for some reason every fourth day i have to refill my radiator and burp the system. The truck will run hot, and the upper radiator hose feels like a rock. I pop the top and she's almost empty on coolant!! resevoir is full and i have NO LEAKS ANYWHERE, i park on concrete at my job and have had friends keep and eye on it. NO LEAKS, but all my darn coolant is gone by day 4. And yes im using coolant, water, and water wetter super cooler. Can anyone help?
I suspect if you sent an oil sample off to Blackstone labs or did this
Block Chek kit
one or both would be positive i.e coolant in the oil or exhaust gases in the coolant.
The running hot and the rock hard upper hose sure sounds like exhaust gases are pressurizing and heating the system.
Block Chek kit
Any billowing white exhaust out the exhaust? What does the underneath side of the oil fill cap look like?
Blamalam
Mar 12, 2022 07:34 AM
WellsR
12
Jul 31, 2015 03:27 PM
TJWilly
Jul 31, 2015 02:05 PM
itzmywife's
Jul 25, 2015 04:55 PM
Avenged
Jul 9, 2015 07:55 AM
