oil pressure problem
Old Oct 8, 2011 | 02:11 PM
ant27's Avatar
got a 85 4runner that PO rebulit the 22re. the problem is that there is no oil pressure when u start it after it has sat for a little bit. but once it does get pressure it works great. i have put in new oil pump and checked oil pickup and it good. only thing i can think of is the oil is all flowing back to the pan. i use napa gold oil fliter, 10-40 oil and a bottle of lucas oil stabilizer. any thoughts?
Old Oct 9, 2011 | 09:44 AM
srbull chris's Avatar
I have 85 4runner rebuiit 22re does same thing whats up ???
Old Oct 9, 2011 | 12:45 PM
ant27's Avatar
and the last couple of oil changes i have done the fliter seemed to be pretty empty.
Old Oct 9, 2011 | 01:42 PM
swampfox's Avatar
A friend of mine had trouble with the napa gold filters being half empty on his Cummins,so he switch to case filters. I had trouble with a wix which is the same filter as the napa gold .my problem was a rattle at start up from the chain tensioner, by changing to a toyota filter the rattle went away.
Old Oct 9, 2011 | 03:17 PM
ant27's Avatar
i have been told that once before a long time ago and will try that when i get paid next. thx
Old Oct 11, 2011 | 02:18 PM
ant27's Avatar
picked up toyota fliter and installed it now to wait and start it up in a while to c if it worked. :-)
Old Oct 11, 2011 | 03:52 PM
ant27's Avatar
did not fix it. maybe got pressure a little bit faster thats about it
Old Oct 11, 2011 | 04:27 PM
92dlxman's Avatar
my 92 22re shows no oil pressure at startup, takes a second before it picks up, bone stock 210,000miles did t chain at 200000. . . . . use fram tg or mobil one filter if its on sale (cause i will only run mobil one sythetic). i dont think its anything to worry about. . . . notice that thats not a very fast moving gauge anyway. could be lagging
Old Oct 11, 2011 | 06:10 PM
ant27's Avatar
ya i know the gauge is slow. and i know the only press in none at start up do to i had a mech gauge under the hood. but i blocked it off because i thought it might b letting air into the block to let the oilf flow down.
Old Oct 11, 2011 | 06:12 PM
ant27's Avatar
the main thing is that i can hear the head and what sounds like a real bad rod knock when i start the truck. but i can also hear it go away before the gauge moves. and in the cold mornings it sometimes will take 5 mins to build any press but as soon as it does its good to go. but that will b the real test tomorrow when i go to work
Old Oct 20, 2011 | 08:07 PM
WeenieHutJr.'s Avatar
The crank in my '85 22re was ground a few thousandths too small and has such low oil pressure that the tensioner cannot effectively do it's job and because of that the engine misses like hell. I have been told that on occasion that the relief valve in the oil pump will get caught up and allow oil to flow back to the crankcase. I may have the latter problem which I hope but will only know after checking my pump. I have exactly the same problem as you upon startup and i'm running pretty thick oil. Chain rattles and I get a nasty knock. I found a good, used 22r bottom end which I will be using shortly.
Old Oct 27, 2011 | 04:22 PM
ant27's Avatar
it has been cold in the mornings the last couple of days and the problem has been alot worse. i have to drive a mile before it kicks on. so im gona lose this eng if i can get it fixed soon so im gona pull the pan off again i check the pickup.
Old Oct 29, 2011 | 06:31 PM
ant27's Avatar
gona pickup a oil pan heater so i can allways have a warm start. let u guys know if they work
bigjstang
Jun 2, 2025 03:56 PM
jbv808
Aug 6, 2021 04:47 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
Sep 4, 2015 09:27 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
