No power and overheating
Old Jun 23, 2009 | 01:35 PM
BerHntr's Avatar
I have an 85 ext. cab 5spd. it has 31X10.50 Buckshots on it. the problem is the severe lack of power. I bought the truck and drove it for a while and just assumed it was the weak 22re. but recently my buddy bought a 85 runner. well needless to say that when i drove it, it was like driving a corvette compared to mine. I don't understand. it has 31X10.50's just like mine. Also here recently it has wanted to start overheating on the interstate. It has been triple degree heat indeces for the past 2 weeks or so but i would think it should be able to keep up. I have to slow down to about 45 to make it drop back down. I checked the timing the other night and for it to run "right" it had to be like 30 degrees out instead of 5 like its supposed to be. so i pulled the valve cover off and set the motor at TDC and the timing chain is dead on. I have also replaced the plugs, air filter, dist. cap and rotor. anybody have any magical toyota wisdom to pass my way? im sick of gettin passed on the interstate by 90 year old grandmas
Old Jun 23, 2009 | 01:56 PM
yotarover's Avatar
thats how mine started doing now i got a milk shake , mines going to the shop after ted from engine builder sends me the 900 front end kit for $154 , new timing chain,oil,water pump, tc cover, head gasket, ,first thing i did was change the plugs,therm drove to shelby nc and on the way back no power at all.
theBurlyone's Avatar
For the power problem try replacing the fuel pump. I had this problem recently as well. Lanes would start merging and I would step on it and get left behind by old ladies... not anymore. Also try replacing the fuel filter and cleaning your injectors. Another thing is that your friends yota could have been regeared at some point in time. You might as well clean the throttle body as well. For the overheat, as stupid as this sounds, check to make sure your radiator is full, it could also be the thermostat. Your fan clutch might be bad as well.
Old Jun 23, 2009 | 01:59 PM
yotarover's Avatar
you might be going through what happened to me, it didn't have much power when i bought it but i drove it and it was fine then it started over heating, so i changed the therm and plugs and wires, still over heated then went back to normal over and over again then it lost it all, no power, oil and antifreeze mix
most everyone has told me it was either the head gasket or the timing chain eat a hole in the cover
Old Jun 23, 2009 | 02:24 PM
BerHntr's Avatar
i've got access an 86 complete motor. Im about fed up and thinkin im gonna rebuild this one bore it 30 over with a crawler cam from enginebldr and header. then when i get it ready i can pull mine and drop the new one in. got a quote from the machine shop i used last time hot tank and bore the block, work the head and put os stainless valves and cam in for about 200.
Old Jun 23, 2009 | 02:45 PM
83's Avatar
83
If you can check compression, do it. That's what most people are leaning towards here...head gasket. That could cause all those problems. Could be a bunch of little stuff, though.
Old Jun 24, 2009 | 01:54 AM
abecedarian's Avatar
search the forums or even google
... search how to set the timing properly.
... you could even use the google qualifier "site:www.yotatech.com" to restrict results to yotatech
given that you're saying 30 degrees helps it run tells me you don't know how to set it. you have a 22re? you put the jumper in, no?
Old Jun 24, 2009 | 05:15 AM
83's Avatar
83
Wow yeah I missed the 30* part...
Old Jun 24, 2009 | 09:42 AM
csharp100's Avatar
The power part is probably bad rings. Mine is the same way only no overheating. I did a compression check and the needle chugs up higher and higher with each turn of the crank indicating bad rings. Time to overhaul and since I have not seen an 84 22r CARBURATED motor being rebuilt in these forums I figured I would document mine then upload what I could.
Old Jun 24, 2009 | 12:49 PM
BerHntr's Avatar
No i do know how to set timing, I have the FSM and a chilton's. jumper the wire, hooked up timing light and adjusted idle and timing for an hour and that was the best it would do. at 5* it runs but will not pull it self out of the garage. I have searched this forum up and down. I know how the members of this site get agitated about redundant threads.
Old Jun 24, 2009 | 12:56 PM
Etype R's Avatar
The distributor could be off 1 tooth, or more. You can pull it out and rotate it slightly, then try it again.
Old Jun 24, 2009 | 04:23 PM
brownbagg's Avatar
timing chain jump
Old Jun 25, 2009 | 05:46 AM
83's Avatar
83
Yeah if the timing needs to be that advanced to run, then I would think that either the timing chain is off a tooth, or the distributer is off a tooth, like the two above posts say.
If you think people get agitated here, check out some of the other sites! People are very nice here. You'll notice yourself, if you stick around long enough, that the questions that can be answered by a simple google search, or by just opening the hood of your truck, tend to annoy people. Not saying that's what you're doing, just explaining. At some point you'll see a thread asking "will these tires fit my truck?" and your blood pressure will elevate a bit...
Old Jun 25, 2009 | 08:47 AM
Etype R's Avatar
After I changed the head gasket on mine, I had all sorts of running problems. Some were vac lines hooked up to the wrong ports, and vacuum leaks. The other problem at first was the distributor was off 1 tooth. I have fixed all of those problems, cleaned the throttle body and IAC, and adjusted the TPS. Its running great now, other then a slight header leak due to a stripped stud.
the1998sr5
15
Jul 14, 2020 08:35 PM
the1998sr5
27
Nov 17, 2015 09:30 AM
Logz808
Jul 26, 2015 07:09 AM
Jeffreynmandy
Jul 18, 2015 08:26 AM
the1998sr5
Jul 16, 2015 06:20 AM
