Need help w/ too tall of truck. Springs and driveshaft questions.
Ok I'm finally able to get another truck again and I have one that I'm specifically looking at. Its a 86 4runner, sas'd, 10" chevy springs, and a 3" body lift. My only real problem with the truck is that it seems too friggen tall in the pics. I have 1 son and another on the way and can't see myself putting 2 kids in the backseat very easily lol. SOOOO... My question is what parts would I have to replace to lower the truck from this height to say, 8" total lift (5" suspension lift + the 3" body). So far from searching around it seems that besides the obvious (springs and shocks) the driveshafts have to be customed. Is that only for springs that go past a certain height (pertaining to if you have stock driveshafts) and if the taper (pumpkin) allows for it? I kinda want to just be able to pick up stock driveshafts and get the largest lift springs that the stock shafts will allow me to. LMK if i'm missing any info that could help. BTW heres a picture of the truck just so you guys can see for yourself.
Oh and if i pick up the truck I'm gonna probably replace the 36's it has on it with 33's or 32's. Thanks in advance.
3'' is the biggest you can go with stock driveshafts.
In my opinion, it is easier to buy a stock(ish) rig and modify it to your liking then it will be to undo a badly modified truck.
1. Leave the leafs
2. Remove the complete 3"body lift as suggested.
3. Also remove the 4" shackles and replace them with 1.5" ones.
4. Remove the 36's and put 33's on.
That should, theoretically speaking, remove right around 6-7" of lift, not accounting for spring sagging, spring angles, etc... BUT... with all that done (mainly talking about the shackles) i SHOULD be able to keep my current driveshafts right?
I'm not sure if this will help, but I would look for a 4-door, especially with a second kid on the way,
Have you ever owned a 2-door 4runner like that one? I have, and even though it was stock, it's still a pain for anyone (over 5 1/2 ft tall) to get into the back seat, let alone trying to put a car seat in there, A kid (like 5-12) would be a little easier because they are small and you can give them a lift into the back, and they can buckle themselves up and stuff, but a baby? that just seems incredibly unpracticle (sp?)
After a few months of having that with 2 kids, I think you (or your signifigant other) is going to get so tired of it that you'll be looking for another vehicle
now if you're just buying this as something to go play around in, and bring the kids along, then that's a whole other story, buy it, lower it back down if need be, and go have fun
loose the body lift and you'll be happy and its so easy to do, it might take a day, with breaks for that six pack. good luck i had the exact same set up and tire combo on my 87 4runner, it was perfect.
Thanks for the info man... I'm gonna try it... Thanks every1....
Tonetrk
08-06-2015 10:06 AM
defrag4
07-31-2015 10:50 AM
