name that engine noise (mp3)
Old Oct 25, 2007 | 03:25 PM
monst's Avatar
Unhappy name that engine noise (mp3)
So the truck I'm about to purchase has a bad noise to it. What do you guys think it is?
http://kradradio.com/space/390305_04.mp3
You might have to turn your speaker up pretty high, its right before shift and it does it twice. It does it every time the engine revs high before shift.
22r
Old Oct 25, 2007 | 03:48 PM
slacker's Avatar
sounds like rod knock to me .. but hard to tell with out seeing .
Old Oct 25, 2007 | 03:59 PM
monst's Avatar
i think the head gasket is blown since i think i can smell coolant in the oil. would that cause this noise?
YodaPala's Avatar
Rod knocking. time to dump some lucas in it and sell it j/k, sucks dude.
Old Oct 25, 2007 | 04:04 PM
SEAIRESCUE's Avatar
If a rod bearing you may be able to feel the knocking in the metal part of the stick shift. Try shifting using metal section below the knob. Push stick hard into the gear selected, away from neutral, will help pick up the knocking. How may miles on engine?
Old Oct 25, 2007 | 04:06 PM
monst's Avatar
odometer reads 143k, would this require the bottom end to be rebuilt?
Old Oct 25, 2007 | 04:12 PM
monst's Avatar
i guess ill take it by a shop tomorrow and find out what it is.
Old Oct 25, 2007 | 04:43 PM
monst's Avatar
i just talked to my brother in law whos truck it is, he said there should be nothing wrong with that truck. Said it was a new rebuild. I really hope its just something knocking around outside the engine =\ arg i hate vehicle trouble.
Old Oct 25, 2007 | 04:51 PM
superjoe83's Avatar
thats definitely a rod knock, a friend's 22re did the same thing, under load you didn't really hear it, but when you backed off the gas to shift it sounded just like your sound clip
Old Oct 25, 2007 | 04:54 PM
monst's Avatar
its not when im backing off its on the way up to the peak then stops when i let off.
Old Oct 28, 2007 | 11:20 AM
xsvtoyz's Avatar
knock under load and gone when unloaded is never a good thing unless you are the mechanic and then telling someone the price is not a good thing
Old Oct 28, 2007 | 11:21 AM
monst's Avatar
i was told it was the wrist pin.
razorman8669
Jul 12, 2015 12:13 PM
Jonny246
Jul 12, 2015 04:51 AM
smiley52
Jul 11, 2015 05:16 AM
Poncho0206
Jul 10, 2015 06:21 PM
Gamble_STi
Jul 7, 2015 07:54 PM
