my clutch clicks
Old Nov 16, 2007 | 02:59 PM
85toy's Avatar
my clutch clicks
ok so somtimes(not all the time) my clutch makes a vlicking noise and i can feel the click with my foot through the pedal. Is this the throwout bearing? Is there somthing i need to lube?
Old Nov 16, 2007 | 03:07 PM
bigt's Avatar
i too have a problem when i let off the gas i read a slight grinding...if i disengage the clutch it goes out.....its been like this for a year
Old Nov 16, 2007 | 03:12 PM
ncpaladin's Avatar
Check under the dash. Press the clutch in by hand while looking up at the clutch pedal linkage. It may be that, being it is a hydraulic clutch and you realy shouldn't feel anything that light through the line. You may need a bit of lube... Unless you take it to the dealer to check, then you'll need a lot of lube.
Bourbonblues
Dec 15, 2017 05:43 PM
pickle6415
Oct 19, 2015 08:08 AM
93toyoguy
3.4 Swaps
10
Sep 18, 2015 04:16 PM
scheuvront1993
Sep 17, 2015 06:17 PM
