Lower Balljoint Won't seperate from knuckle!
I'm in the middle of replacing the upper and lower ball joints on the passenger side... I unbolted the 4 bolts holding the lower bj to the knuckle assembly, and I used my 2-arm puller and broke the compression fitting at the A-arm, but the two flat surfaces (bj and knuckle) won't separate..... I've tried the BFH and chisel method and it won't break it free. I also tried to thread the nut back on a little and put my bottle jack in between the two a-arms..... it didn't budge.
Ideas? I don't have a torch. Am I missing something?
Yeah, finally got the lower. I tried the B'erFH trick and it worked.... ended up bending and then snapping one chisel, but it separated.
I'll have to tackle the upper one on Thursday when I have time off again.
Cool, I'm getting ready to do mine too...I'm putting in new upper arms, and my bottom ball joints and tie rods are ready to go I think. Gonna order them and let the swear words and sparks fly...
Get a two-arm puller!!!! And get ready to be amazed at how much tension those compression fittings hold!
I suggest ripping the whole knuckle apart.... the FSM says to and I tried to get at the uppers without doing so, and couldn't get a good angle. So set aside the time and tear into it!
Athansinis
Jul 27, 2015 08:38 AM
FS[SouthCent]: TX Third Gen UCA and LCA low miles Taco
KyleT
Jul 21, 2015 07:54 PM
FS[NorAtl]: set of 4 ball joints. any torsion bar ifs 4wd
akaphilly
Jul 9, 2015 02:27 PM
