Instaling Clinometer
Old Nov 14, 2007 | 06:17 PM
Dexter350k's Avatar
im trying to get my dashboard off in my 85 runner and it seems like its bolted on the right side top... their was a clip on the left side and looks like bolts or just really stuck in with clips... i just want to make sure its clips befor i pull my heardest to tear it off... i cant pry on it because i dont want to crack the windsheild... anyone know what to do?
Old Nov 14, 2007 | 08:46 PM
CyMoN's Avatar
https://www.yotatech.com/forums/f116...umbers-102344/
Old Nov 14, 2007 | 09:18 PM
paxil4x4's Avatar
Drama Queen/Banned
You have to pull the right A/C vent out which is really a PITA. and there is a 10mm nut behind it.
Old Nov 15, 2007 | 03:05 AM
Dexter350k's Avatar
thanks guys!
Old Nov 15, 2007 | 04:19 AM
881stGenRunner's Avatar
whenever you go to drill holes for the inclinometer there are already pre-made holes underneath the dash pad. dont try to line it up and do it by eye
Old Nov 15, 2007 | 04:08 PM
Dexter350k's Avatar
all done!!! thanks agian guys!
Old Nov 15, 2007 | 07:06 PM
ozziesironmanoffroad's Avatar
that looks really good! now i just need to find one in my dashes color... lol
Old Nov 15, 2007 | 07:50 PM
bruzryoda's Avatar
where did u find that inclinometer?? i have one from a Montero but, i can not put it any place on my 81 wheelr.
Old Nov 16, 2007 | 02:59 AM
Dexter350k's Avatar
found it on ebay... paid $100 for it... its worth it to me... i couldnt pass it up when i saw that it was the same color as my interior
Old Nov 16, 2007 | 05:06 AM
lookin good man, that dash pad is a pain in the arse to get off, isnt it.
Old Nov 16, 2007 | 01:05 PM
Dexter350k's Avatar
yeah the dash is a beotch
Old Dec 6, 2007 | 09:05 AM
dannydsmv's Avatar
Clinometer Mounting
Thought I'd resurrect this post. I have an '88 pickup and I just bought a used Clinometer, complete with wiring harness, for it. Can anyone tell me if the holes are already pre-drilled and if the wiring connector should already be in place? Also, I looked at my FSM and it doesn't show much. Will I need to cut away any of the dash pad or does the Clinometer mount right on top of the dash pad essentially sandwiching the pad between the Clinometer and dash pad frame? Thanks!
dannydsmv
1988 Toyota Pickup V6 5spd SR5 Xtra Cab
2003 Subaru WRX Wagon
2001 KTM Duke
Old Dec 6, 2007 | 10:17 AM
leiniesred's Avatar
88 SR5...you'll find the other end of the plug for your clinometer already in the dash.
Flip the dash top over after you get it out and you'll see the holes pre-drilled where the studs and the wires from the clinometer go. No serious cutting, but it isn't really a "reversable" addition with the new holes in the dash.
Old Dec 7, 2007 | 11:26 PM
XtraSlow_XtraCab's Avatar
What if tis not an SR5 truck? Do you have to hardwire the inclinometer into the harness then?
Old Dec 8, 2007 | 03:56 AM
Dublin's Avatar
It won't make a difference SR5 or not, the wiring harness on the inclino has male and female connectors. The connectors are daisy chained with the climate control lights. Unplug the climate harness, plug the inclino into that and then the other inclino connector to the other half of the climate control.
Old Dec 8, 2007 | 04:00 AM
Belize Off Road Team's Avatar
X2
Old Dec 9, 2007 | 01:32 PM
HAHA! Now I just have to FIND an inclinometer to install.
nvdesertrunner
May 11, 2020 08:18 PM
wwjr
Sep 7, 2015 09:27 AM
punks_is_4x4
Aug 21, 2015 01:35 PM
Esibnitsud
Jul 30, 2015 08:19 PM
