I Need A Bottle
Old Jun 11, 2017 | 07:14 PM
L5wolvesf's Avatar
I Need A Bottle
My next lil project to get my 84 Pu in better shape is to find a windshield washer bottle/reservoir and the pump of course. My choices seem to be used, used or used. However, I came across new ones for the 89-95 trucks at the same price as the used ones.
So my question is has anyone put an 89-95 reservoir and pump in an 84 85 etc? Also, since I don’t have the res in my truck can someone post up a pic of theirs in the truck so I can try to compare them
Thank you
Old Jun 11, 2017 | 08:08 PM
fasterspider's Avatar
The reservoir is not easy to get a picture of at night but, I have to pull and reset my battery in my 85 tomorrow morning so when I do, I will photoblast it for you and if you text me tomorrow after 8am California time, I'll send the image to your phone.
818-259-8690
Old Jun 11, 2017 | 11:32 PM
wyoming9's Avatar
Red face
Unless this has to look perfect for some reason .
Any washer tank that fits where you want and a new pump will work .
I have mine mounted on the left inner fender to brackets I made .
I don`t remember just what the tank came out of.
Old Jun 12, 2017 | 03:08 AM
Terrys87's Avatar
It has been a long time ago but it seemed I tried to use a 89-95 bottle on an 84-88 and it did not fit. Not completely sure if I am correct on that. As far as pumps, I have used washer pumps off of 04 models and all I had to do was change the connectors.
Old Jun 12, 2017 | 05:47 AM
eBay has what you need, just look at this.
http://m.ebay.com/itm/1984-85-86-87-...p/401317538274
Old Jun 12, 2017 | 05:48 AM
New pump motors only cost ten bucks, mine did and still works three years later.
Old Jun 12, 2017 | 06:49 PM
Here is my very dirty washer fluid bottle in it's original position with an $8.95 pump motor from Parts Geek.com
Old Jun 13, 2017 | 04:43 AM
L5wolvesf's Avatar
Thanks for the info and pic. Been swamped the last couple days so I'll check into this further later.
Old Jun 13, 2017 | 09:30 AM
highonpottery's Avatar
Theres lots of options for "universal" ones too. Simply hook up the 12v and the water lines, done. Who cares what it looks like as long as it fits the location.
Old Jun 13, 2017 | 01:58 PM
flg8r22's Avatar
I'm going to Atlanta tomorrow for a 90 4Runner. I'll let you know the condition
Old Jun 15, 2017 | 12:42 PM
L5wolvesf's Avatar
I would like the truck to look as factory as possible as I will be selling it. I don't fit in small pickups well and want to get a 4Runner.
Old Jun 15, 2017 | 12:46 PM
L5wolvesf's Avatar
Between Terry's comment and your pics I can see that the later reservoirs won't work in the stock position.
​​​​​​​There are a bunch of 84-86 used ones for around $20 via car-part.com. I may go that route.
Old Jun 15, 2017 | 12:51 PM
L5wolvesf's Avatar
Another good score huh? You're really rollin with the Toyota business.When I was dealing with a friend who repaired VWs I told him to do as many flips as possible.
Each rolling car is a potential customer/income. It worked out pretty good until other stuff happened.
A bottle from a 90 won't fit and shipping from Fla is gonna bite. But I do have you in mind for parts.
The reason I bought an Xtra-Cab is because the seat goes back far enough unlike a small cab Yota where I'm jammed into the steering wheel and my knees are denting the dash board with the seat back all the way on it's tracks.
Old Jun 15, 2017 | 01:08 PM
L5wolvesf's Avatar
I know the feeling - I have to drive kinda bow legged in mine. I rarely see Xtra-Cabs around here.
Old Jun 15, 2017 | 01:19 PM
They are better preserved in Arizona and they are out there if you are persistent in your search.
I paid too much for my Yota in 2014, replaced the engine with a freshly rebuilt eBay engine in 2015 that passed smog with flying colors and just finished the top end overhaul today to pass smog for 2017 because she failed due to garbage Chinese valve guide seals the rebuilder I bought the engine from used during rebuild.
Old Jul 17, 2017 | 01:14 PM
L5wolvesf's Avatar
I got a washer reservoir with a pump and want to test the pump before installing and switching out the connector. I checked the wiring diagram and I can’t tell which wire is power and which is ground. I searched here and the closest I came was this -
If you find a pump frozen up, I have ran some leads from the pump straight to the battery and reverse polarity every 5 seconds or so and got them freed up that way. 2 of the pumps I have done that to are still working great. That is one of the fixes I found and have it listed there as well.
There is a blue wire and a blue/white, any idea one which is which?
Old Jul 17, 2017 | 02:03 PM
Co_94_PU's Avatar
It is just a little DC can motor, the polarity only matters once it is permanently attached as you might have guessed by Terry's message. You can hook it up either way the test the brushes.
Old Jul 17, 2017 | 02:09 PM
Co_94_PU's Avatar
88 FSM says solid is power, stripe is ground.
Old Jul 17, 2017 | 05:43 PM
L5wolvesf's Avatar
XLNT, CO94 you sir are a gentleman and a scholar.
