How to identify a 5-spd
Old Sep 19, 2007 | 05:42 PM
Smokey74's Avatar
Hey guys, I just picked up a used Toyota 5 spd and transfer case for cheap. The guy wasn't sure what it came out of. I'm looking to do a swap into my 85 4runner, how do I find out if the tranny I bought is the right one? He thinks it came out of an 87 4runner but not 100% sure. I have pics if it helps. Thanks, Smoke
Old Sep 19, 2007 | 07:39 PM
4Crawler's Avatar
http://www.marlincrawler.com/htm/tra...ansmission.htm
Old Sep 19, 2007 | 07:41 PM
DeathCougar's Avatar
post up a pic and I will tell you.
EFI Trannys are Top shift cases
Carb and Turbo trannys are forward shift cases
If it came from an 87 4runner, its a Top Shift with 6 bolts holding down the actual trans shifter plate. (4 more hold down the tcase shifter)
Old Sep 19, 2007 | 08:38 PM
dropzone's Avatar
Fossilized
http://www.4x4wire.com/toyota/faq/parts/
link to factory service manuals:
http://www.ncttora.com/fsm/index.html
Old Sep 19, 2007 | 08:50 PM
XtraSlow_XtraCab's Avatar
I believe that if you look at thie shift knob... the numbers should count up to 5. And there's a little stick behind the big stick.
lol Sorry, I couldn't resist being a smart ass. The subject line tickled my brain
Old Sep 20, 2007 | 01:12 PM
Smokey74's Avatar
Here are some pics. I appreciate the help.
Attached Thumbnails How to identify a 5-spd-09-20-07-001.jpg   How to identify a 5-spd-09-20-07-002.jpg
Old Sep 20, 2007 | 01:15 PM
Smokey74's Avatar
4Crawler and ocdropzone, thanks for the links.
Old Sep 20, 2007 | 01:26 PM
4Crawler's Avatar
Unless it is a later model EFI, they will have W56C, D or E trannys with forward shift t-cases with EFI.
Old Sep 20, 2007 | 01:48 PM
84-88 EFI Top shift W56
Old Sep 20, 2007 | 01:49 PM
ya i know but we are talking 85-89 style
Old Sep 20, 2007 | 05:12 PM
Smokey74's Avatar
Excellent!! So it's exactly what I need for a swap into my 85 Runner, right?? Do you know if I will need the different drive shafts for the swap or will my shafts from the Auto work?
Old Sep 20, 2007 | 05:26 PM
Automatic drivelines are different lengths. You will need new shafts.
Old Sep 20, 2007 | 06:37 PM
Smokey74's Avatar
Thanks again.. Pretty sure the guy I got this from has shafts too. I know I need the clutch pedal and linkage and a clutch pack but is there anything else I'll need??
Old Sep 20, 2007 | 11:02 PM
Assuming you are doing a MT conversion, you will need the following parts:
Transmission with TCAse
Drivelines
Shifter Assys
Pedal assy
Master cylinder
Slave cylinder
Hard Line from master to bracket
Soft line from bracket to slave
Someway to bypass Neutral Safety switch, as the MT vehicles run on a Clutch start set up.
Old Sep 21, 2007 | 02:35 PM
Smokey74's Avatar
Drivelines
Shifter Assys
Pedal assy
Master cylinder
Slave cylinder
Awesome..Thanks. I talked to the guy today, he has everything I need.
Corvoid
Oct 13, 2015 08:55 AM
JUICE222
Oct 13, 2015 08:50 AM
Bill854x4
Sep 20, 2015 04:32 PM
jdt79
Sep 16, 2015 02:14 PM
