Help Removing Autolocker
isn't the spider housing and the carrier the same thing?
anyway, pop the carrier lock pin out(big pin going threw middle). then use a pick of some sort and pull all the springs out. then push the pins all into one side or the other, then line up the flat spots of the locker with the carrier, and then pull them out.
Ah springs and pins thats what i was missing. Thanks
I thought the carrier was the main carrier that bolts to the axle housing and the spider housing is the little thing the ring gear bolts to.. is that correct?
no, the thing that bolts to the rear end, is the housing, aka 3rd member, aka pumpkin. the thing that the ring gear bolts too is the carrier.. thats why the bearings on the sides are called carrier bearings
gyroscope7
7
Sep 27, 2015 08:39 PM
LotOMiles
Sep 14, 2015 11:45 PM
Rickstwowheels
Sep 9, 2015 06:12 PM
