help on performance problem
Old Aug 18, 2016 | 12:32 PM
stevehotwirered's Avatar
I have a "92" 4Runner with a 3.0 liter 5speed tranny with 220,000 miles on it,replaced head gaskets on it and it has no compression on #1 and#6 cylinders at low idle,but does not burn any oil and will still run down the road at 80+ mph and has an audible miss at idle. have replaced all plugs, wires,cap and coil.any ideas on what i need to do to correct it?
Old Aug 19, 2016 | 09:53 AM
osv's Avatar
osv
that's not logical, how exactly can you tell that there isn't any compression, only at idle?
did you check the valve lash?
Old Aug 21, 2016 | 05:47 PM
did compression test after installing head gaskets and had no compression on #1 & 6cylinders
Old Aug 21, 2016 | 05:52 PM
coil wire pulled,and had wife crank it over and had compression on all cylinders except 1 & 6
Old Aug 26, 2016 | 11:35 AM
thefishguy77's Avatar
autocorrect fail
Did you do the head gaskets yourself? Have you checked the valves? Are you sure you had a good seal l for the compression test on 1&6?
Old Aug 26, 2016 | 12:01 PM
wyoming9's Avatar
Did you put coolant in the engine ??
Pressure test ?/
Why did you replace the head Gaskets ??
Did it get Hot ?/
Check for cracks in the head ??
Just what numbers did you get ??
No compression failed head gasket !!!
Bad valves got the valves between 1 and 6 mixed up
Cracked heads
Rings gone
Cam lobes wiped !!
cascadia
Jul 24, 2016 09:45 AM
gixxer
Feb 18, 2016 06:17 PM
ethanethan
Feb 16, 2016 06:10 PM
Paul S
Jun 20, 2002 05:07 PM
BlackRunner
Jun 17, 2002 07:49 PM
