Help. Fuel pressure loss on 85 22re
Old May 7, 2019 | 02:11 PM
934runnerdeluxe's Avatar
So this is my first post, after roughly 6 months of research and hundreds of dollars in parts and and time and lots of hair loss. So I ask the best place for answers.
Lets get to it.
I have an 85 4Runner 22rec 4x4.
I rebuilt the motor this winter during a lay off and stabbed it back in the truck and when trying to get back going it wouldn’t start.
I have since got it to idle. With a truck load of new parts.
NEW:
4 fuel pumps
injectors
fuel pressure regulator
filter
afm with a known good one
coil
plugs and wires
distributor cap
Injector plugs
Coolant temp sensor
cold start injector with known good one
The problem is the truck will idle fine and will rev up to about 2000 rpms and then just fall on its face. I hook a fuel pressure gauge up it will bring it up about 38 psi with a jumper and key on. With the truck running at idle, smooth as silk, with a little bit of throttle the fuel pressure bottoms. I have covered the main feed line on the pump housing with a rubber fuel hose so I know it’s not bleeding by there. No visible fuel leaks at all. Truck is dry as a bone. All grounds and connections seemed to be spot on. 12v at the pump at all times.
No codes
I am lost on this, any suggestions on this would be awesome. Thank you guys.
I’ll try to get some videos up to show what’s going on.
Old May 8, 2019 | 08:02 AM
Co_94_PU's Avatar
Probably a crushed or clogged fuel supply line
Old May 8, 2019 | 09:20 AM
trevor1985's Avatar
5 Year Member
Have you checked the throttle position sensor? That could be a culprit if it falls off after a certain amount of throttle
Old May 8, 2019 | 10:47 AM
Co_94_PU's Avatar
Doesn't work like that. The pump should be supplying enough volume for the regulator to maintain the designed pressure with the injectors essentially wide open (near saturation).
You can pull the return line off the regulator and plumb it into a catch container. Run the pump via the diagnostics jumper for one minute. Then measure the fuel, it should be very close to 500cc.
The scenario with a fuel line clog will show less volume due to the restriction. It is similar to having a fuel pressure regulator up steam of the injectors, the pressure behind the clog will be maintained by the pump's internal pressure release. Think of a garden hose, you can slightly open the tap and pinch the hose to build up pressure but what comes out the end of your wide open spray nozzle is just a trickle. Close the spray nozzle to a point that matches the tap opening and you have a good spray not a trickle.
This clog could be a physical kink, it could be rust, it could be sludge, and even any combination of these things.
Old May 8, 2019 | 01:44 PM
I took the line loose from the pump, and loose from the filter. I then hooked about 90psi of air through the main feed line for about 45-60 seconds. (Whatever was left in the tank) Granted that doesn’t exactly tell us anything. Now I have visually inspected the lines and it doesn’t look like there’s any rust or kinks down the body that you can see. But sludge and rust on the inside, is there anything you can put in the lines to eat this stuff out?
As far the tps I have adjusted and triple checked it to make sure it’s good. It checks out good on all accounts.
Old May 14, 2019 | 05:25 PM
Bump*
Old May 14, 2019 | 08:48 PM
Co_94_PU's Avatar
Originally Posted by 934runnerdeluxe
Bump*
Look thru Terry's threads, i couldn't find it but I'm not as motivated as I expect you will be, I don't recall if he uses solvent of any kind to clear fuel lines.
BUT! You didn't say anything about the test results just jumped right to blowing a little bit of air through it. This means you don't know if it was actually a flow problem or have any baseline to compare any possible progress to.
Old May 15, 2019 | 10:26 AM
old87yota's Avatar
Here is one of Terry's posts. He just used compressed air to clean out the lines. I thought he put something in the lines on when of his trucks to soak for a while.
Here is his post on his 1988 4Runner: https://www.yotatech.com/forums/f199.../#post51633022
I found a thread where Terrys87 replies on how he cleans out his lines. He says on really dirty fuel lines, you can use Marvel Mystery Oil or PB Blaster and let it soak for a while.
https://www.yotatech.com/forums/f116...em-too-266872/
If you have the fuel system apart, it doesn't hurt to clean out the lines at the age of these vehicles, even if dirty fuel lines isn't what is causing your problem.
Old Jun 3, 2019 | 07:39 PM
*Update* sorry for not being quick to post back. Last few weeks have been crazy trying to get the sxs ready for a ride and then driving ten hours round to ride to just watch someone break an axle and load up🙃.
But Back to the point. got to mess with it this weekend and PROBLEM IS SOLVED! Turns out after fb mechanics telling me “no the fuel pressure damper would never cause this problem.” It turns out it was. Ended up just drilling a hole where the man fuel line sits and turning that thing into a big banjo bolt. Truck runs like a top. Thank you guys for the info you have given. And I’m happy to finnaly put my 4Runner back on the road after she’s been sitting for about a year now.
Don’t have any pictures of the truck but here’s the pretty little engine before it went back into the truck.
sam_KOR
Sep 25, 2016 09:14 AM
Brandonn Mixon
Sep 12, 2012 04:29 PM
Junkers88
Nov 11, 2011 10:44 AM
toyotalytrevor
Apr 11, 2008 07:35 PM
gte718p
Mar 15, 2008 08:13 PM
