Help!!!
Old Aug 1, 2008 | 12:29 PM
Over-Rever's Avatar
Help!!!
ok i got an 84 runner about a month ago and it was in horrible shape but i've got it running now and i have a temperary radiator in it but now i have some questions about a few things... ok first its been hit on the front left side. when i first got it running i took it for a test drive and it pulled to the left bad i found out my torque rod had snaped and fixed it but it still pulls to the left but not near as bad my front left shackle is laying on the frame could this be an issue? also when i come to a stop there is vibration coming from under my feet it sounds like exuast but i have no clue what to do about it. i was also wanting to lift it to get some 33s on it and i was thinking about just blocking the suspension for now.... anyone feel like helpin out. im so happy to own it its a struggle not to wheel it instead of work on it...lol
Old Aug 1, 2008 | 12:51 PM
wrnchplr's Avatar
first off what is this rod your talking about??? if it's an 84 it has a solid axle.
if the shackle is on the frame that is bad.
don't put blocks on the front!!!!!! I'm not even sure they would fit....
if it is still pulling there could be a issue with the frame being bent. some pic would help allot.
Old Aug 1, 2008 | 12:56 PM
Djlarroc's Avatar
Yeah, the shacke on the frame sounds bad. Have it looked at by a mechanic.
Old Aug 1, 2008 | 01:51 PM
4Crawler's Avatar
Sounds like the spring shackle is too short for th installed springs. See how I solved that identical problem on my '85 below:
- http://www.4crawler.com/4x4/CheapTri...l#Applications
Old Aug 1, 2008 | 02:37 PM
grovedogg's Avatar
if it;s been hit, or the hit-ee, then there could be many drastic problems, check the springs for de-arching, or warping, check all stering arms, and linkage... frame would be my last spot to check, just cuz if it's the frame ur effed...
as far as the vibration under ur feet, what size/type tires are you running? I have a 84 Runner with 31x10.5 BFG Mud Terrains, they make a lot of noise, and vibrate just under 10 mph's,...
Old Aug 1, 2008 | 02:47 PM
Over-Rever's Avatar
re
the torque rod its going from the axle to the front frame on the left side... ill get some pics asap... how should i lift the front if i cant use blocks?
Old Aug 1, 2008 | 03:03 PM
Over-Rever's Avatar
my leaf springs are like frowning on both sides and there is even a broken one on the right side but it sags to the left.... and the shackle on my right is about an inch off the frame...
Old Aug 1, 2008 | 03:13 PM
85toy's Avatar
the shackle on the frame sounds like the front crossmember could have been bent when it was damaged.
Old Aug 1, 2008 | 03:53 PM
Over-Rever's Avatar
what is the front cross member
Old Aug 1, 2008 | 04:33 PM
85toy's Avatar
sorry maybe i called it the wrong thing, um its what the front of your front leaf springs are attached to.
Old Aug 1, 2008 | 04:37 PM
4Crawler's Avatar
Spring hanger is what the front spring eye is bolted to to attach it to the frame. The spring shackle connects the rear spring eye to the frame and swings back and forth as the spring compresses and extends.
Old Aug 1, 2008 | 04:43 PM
85toy's Avatar
sorry, yep thats what i was trying to say.
Old Aug 1, 2008 | 06:31 PM
Over-Rever's Avatar
i think it was ok ill have to check it again just to make sure and ill get back...
what about when i come to a complete stop it makes a crackling sound almost like a grinding sound
Old Aug 1, 2008 | 06:40 PM
4Crawler's Avatar
Could be something broken, making a metal-on-metal grinding noise. See if you can have someone drive and stop the truck close to you and see if you can isolate where the noise is coming from.
Old Aug 1, 2008 | 06:55 PM
wrnchplr's Avatar
I can't remember the name of that....I took mine off....I would buy some lift springs or put some rears up front and chevys in the rear. it's a cheap and flexy lift.
rears up front
chevy in the rear
Old Aug 1, 2008 | 06:58 PM
4Crawler's Avatar
Only way to eliminate the torque rod, at least for a street driven rig, is to put on crossover steering. If you keep the stock push-pull steering, the torque rod is rather important, at least on the road.
Old Aug 1, 2008 | 07:09 PM
Over-Rever's Avatar
rears up front
chevy in the rear
like how cheap and where could i get them and what do i ask for just chevys?
