heater/blower will not work
Old Mar 13, 2012 | 04:07 PM
warmonger88's Avatar
First of all, I have already searched the forums, and no dice.I have done a lot of work under my dash recently and had everthing removed. The prevoius owner had the blower wired directly to the battery on a switch, so I converted it back to stock. I replaced the blower resistor twice and it worked for a week or so with a three speed resistor, but I bought a four speed once I found one. I put it in this morning and nothing worked. My slider control for hot or cold is not working either( I believe it is seized), But I was wondering if anyone else here had to solder their fan switch ( on the climate control cluster) back together and has there been any success( I had a wire pulled off of the board)? Could really use an adult on this one guys. Thanks!
Old Mar 13, 2012 | 05:02 PM
BMcEL's Avatar
https://www.yotatech.com/forums/f116...ctures-227171/
Searched 'blower switch repair yotatech' on google. 1st result.
Old Mar 13, 2012 | 09:58 PM
I actually just had to put a wire back onto the copper plate, but I think I might tear back into it an give this a try. I don't get power at any level though, thats what bothers me. Every other post I have found, the blower works on at least one setting.
Old Mar 13, 2012 | 10:25 PM
BMcEL's Avatar
Check the heater fuse & relay behind the glove box.
ashersullivan88yota
Jan 18, 2022 05:37 PM
sandyota
Feb 4, 2021 11:16 AM
Sep 4, 2015 09:27 AM
crashburnoveride
Jul 10, 2015 06:39 AM
madxman21
Jul 9, 2015 10:26 AM
