Heat Shield Needed?
Old Apr 18, 2009 | 12:18 PM
thewjsand's Avatar
Heat Shield Needed?
22REC engine
Do i need the heat Shield around the exhaust manifold? All but one of my bolts has broken off in the header and it is only hanging by one...
Would i risk melting or causeing damage to the hoses in the general area if i do not have the heat sheild on?
Let me know if you have your shield on!
Also anyone know an affordable header replacement?
Thanks
M
Old Apr 18, 2009 | 01:01 PM
4Crawler's Avatar
Probably not essential, I run a header without any heat shielding aside from the ceramic coating and the OEM exhaust manifold gasket and no problems:
- http://www.4crawler.com/4x4/CheapTri....shtml#Exhaust
Just make sure your spark plug wires are held up along the valve cover. Once on a trail ride, one fellow had a plug wire fall on the exhaust and short out when the insulation melted.
85TurboRunner's Avatar
The heat shield has broken off every truck I've had. I guess if you really wanted you could drill out the bolt holes and re tap them, but it isn't going to hurt anything to leave it off.
bigjstang
Jun 2, 2025 03:56 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
bryan34w
Jul 6, 2015 05:53 PM
Jnkml
Jul 6, 2015 01:20 PM
mickyd9990
Jul 6, 2015 09:01 AM
