headlight issue
Old Jan 31, 2018 | 09:04 AM
  #41
jakey poo's Avatar
He probably has aftermarket housings like I do that get rid of the sealed beam. Although now I see he has a '91
Old Apr 30, 2025 | 06:26 AM
  #42
TN_Mule's Avatar
Originally Posted by 4Crawler
What information is it that you need?
How to repair the switch, or at least how I repaired my switch:
- http://www.4crawler.com/4x4/CheapTri...eadlight_Combo
Does flash mode work (pull back on the dimmer switch)?
New Member here. Got a 1990 Toyota truck. Lights do not come on when you turn them on. The bright light indicator on the dash panel is lite up in either lo or hi beams, but no lights. You can pull back on the dimmer switch though and the headlights come on. Any help or ideas of how to fix this? Is it as simply as cleaning the contacts?
Old Apr 30, 2025 | 06:33 AM
  #43
4Crawler's Avatar
Likely the contacts. What I did was observe which contacts moved in flash mode and then checked which moved between high and low beam modes. In my case low worked, high didn't, so I focused on cleaning the contact that moved in high beam mode.
Old Apr 30, 2025 | 06:38 AM
  #44
TN_Mule's Avatar
Thank You Sir for the speedy response.
Old Apr 30, 2025 | 09:06 AM
  #45
TN_Mule's Avatar
Old Apr 30, 2025 | 09:17 AM
  #46
TN_Mule's Avatar
Originally Posted by TN_Mule
found this in the floor board. Any ideas?
Old Apr 30, 2025 | 09:31 AM
  #47
TN_Mule's Avatar
Put back together
Found where the bb went. Parking lights work, but still no headlights. Can pull back though and get the high beams to turn on. Any advice is much appreciated.
SomedayJ
Nov 20, 2022 02:04 AM
ranger_t_f_u
Jan 26, 2013 01:57 PM
gary96360
Jul 29, 2009 10:25 AM
Ed H.
7
Dec 7, 2008 10:11 PM
trdslinger
Dec 29, 2004 08:04 AM
