head question
Old Jan 2, 2009 | 07:54 AM
defyota's Avatar
head question
i bought an 85 22r with a cracked timing cover. it sat for 5 years ad the head totally rusted out. so i bought a 22r off a friend . i pulled the head off the donor motorand the area by the valves is a different shape than my old head. and the pistons are different too. can i still swap these or shoul i look for a new head?
Old Jan 2, 2009 | 08:26 AM
DeathCougar's Avatar
NO, they are different, and will not work in a direct swap situation.
If the exhaust ports are lightbulb or pear shaped, that is an 85-95 Head. If the exhaust ports are round, its an 81-84 style.
Old Jan 2, 2009 | 08:33 AM
defyota's Avatar
they both came out of 85s and i sat the new head on my block with no interferece it just looks like i would have a lower cylinder compression. would i be able to take the cam, valvles rocker arms, springs and all that stuff and put that on my head? it all looks identical
Old Jan 2, 2009 | 08:37 AM
The intake ports are different as well, so you will need the intake AND exhaust manifolds from the other engine. If the one with round exhaust ports came out of an 85, it was a tranplant and the WRONG engine. They may look identical, but one has a different deck height than the other.
Old Jan 2, 2009 | 11:11 PM
herpestes's Avatar
http://www.lcengineering.com/technot...&catid=1&id=49
Old Jan 3, 2009 | 04:29 PM
Dyenasty's Avatar
Well i have a head that is short with pear shaped ports and another head that has round ports that is taller i was reading in one forum that says pear shaped ports are for a 85 to 95 but another thread that said in 85 they went from a short head to a taller head how is that possible i have a short head with pear ports and also i have a round port head that is ttaller??? is this one of those things that you call " rare " or is somone giving false information
Old Jan 3, 2009 | 09:37 PM
herpestes's Avatar
refer to the info on the link above on the bottom is a picture that shows what to look for between the 22re. there should be a casting on the exhaust side of the block.
Old Jan 4, 2009 | 10:00 AM
rbmoomba's Avatar
The "newer pear shaped exhaust ports head" is the way to go, that is the motor set up you want. Lighter pistons, more efficient yada yada yada. Keep looking for a head. A complete newer model head sold on ebay for $45 a month or so ago, so just keep your eyes open. Good luck
bigjstang
Jun 2, 2025 03:56 PM
kgcwb44
Jan 29, 2023 10:02 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
nonstop
Jul 24, 2015 06:29 PM
Coreyr384
Jul 10, 2015 11:13 AM
