Hard start after changing fuel pressure regulator
Old May 7, 2013 | 01:30 PM
Bfinkas's Avatar
85 22re
After noticing a small leak from my fuel pressure regulator I changed it. The new one I got I had to crank the truck and pump the pedal for almost a minute before the truck started. So I took back that regulator and got another new one. Well this one was a bit better but still takes about 15 seconds to start... If I turn the truck over and pump the gas for a few seconds and stop then turn the truck over again it starts up. Possibility I got 2 bad regulators?? Is there a way to check this? It has always fired right up btw...
Old May 7, 2013 | 02:18 PM
ojm3's Avatar
Fuel pump bro!
Old May 7, 2013 | 02:29 PM
Bfinkas's Avatar
Originally Posted by ojm3
Fuel pump bro!
That's what I was kinda thinking. The check valves were leaking through and not holding fuel/pressure in the line... But it started fine with my old leaky regulator...
Old May 10, 2013 | 01:59 PM
ojm3's Avatar
The old regulator might not have been working properly. Upon the install of a new properly working regulator the added stress on an old fuel pump could cause it to stop working properly.
Old May 10, 2013 | 03:20 PM
Bfinkas's Avatar
Ok awesome. Thanks for the replies. Now if I could only find a pump with the sending unit (since mine doesn't work) I would be set!!!
Old May 15, 2013 | 03:27 PM
ojm3's Avatar
How did the repair go bro?
Old May 15, 2013 | 11:33 PM
Bfinkas's Avatar
Been super busy at work and going on vacation for 2 weeks now. So after memorial weekend I will get it done and let you know
Ichneumon
Sep 27, 2015 04:21 PM
Dillon1983
Jul 7, 2015 06:47 PM
bigblue82
10
Jul 6, 2015 08:27 AM
94 Newbie
Jul 6, 2015 04:23 AM
jmc88runner
Jun 18, 2015 03:39 PM
