half tank sputter 22re
Old Apr 5, 2010 | 07:06 PM
  #41
GranVille-4crawler's Avatar
Yeah luckily some crazy old timer owned mine. Untouched susp and wiring. Even had stock size highway tires on it. I'll keep you posted on this
Old Apr 5, 2010 | 07:20 PM
  #42
myyota's Avatar
Thats a good find, someone that just bought it and drove it and didn`t hack it up. So once you get this problem worked out you will have a good running4Runner. How many miles are on it ?. Another thing im wondering about is that you are calling it a graingeville adition, ive never heard of that before, do you have any info on that ?.
Old Apr 5, 2010 | 07:26 PM
  #43
The odo reads 158 but my speedo cable is shot. My buddy who has an 85 also with 220k on it says it runs and rides way stronger smoother than his. I'm guessing 170k. The old guy said he used it as a hunting truck but he must have just drove it to the lodge then hopped on a 4wheeler cause the body is perfect. It was customized by a company in ilkhart il. Its got granville badges and door handles. Red velvet int and a dif rear seat that doesn't fold down flush and its actually quite comfy. And its got a sweet 2tone fade paint job. It used to have running boards from the same company too. Those were the first things to go
Old Apr 5, 2010 | 07:28 PM
  #44
I use my phone to get on this forum otherwise id have pics up. I have some pics on fb if you have that. Names dylan feeser
Old Apr 5, 2010 | 07:33 PM
  #45
myyota's Avatar
That sounds like a nice 4Runner, ive never seen one like that before, can you post a picture of it ?.
Old Apr 5, 2010 | 07:45 PM
  #46
I can't post pics with my phone on here for some reason but if you pm me your email I'll shoot ya some pics and then you can post em
Old Apr 5, 2010 | 07:55 PM
  #47
myyota's Avatar
I will send you my email, but when it cime to posting them here, im a bit computer challenged, i can never get it to work for me.
Old Apr 5, 2010 | 07:58 PM
  #48
Lol I think u just clic that picture of the mtn right above the txt box. But yeah I'll send some your way
Old Apr 5, 2010 | 08:02 PM
  #49
myyota's Avatar
I sent you a pm with my email. Im going to try and get a few new pictures of my 4Runner this weekend so i can update my signature picture.
Old Apr 6, 2010 | 03:22 AM
  #50
I sent those pics let me know what you think
Old Apr 6, 2010 | 01:35 PM
  #51
Kiroshu's Avatar
That would have been my next sugestion as well. Some peeps are on the ball on this site. The cold start injectors are acctaully bad for leaking as well as the Thermal time switch (cold start time switch)malfuctioning. Its a switch located i believe next to the coolant temp sensor should be the one on the right. Its 2 connectors located under the throttle body. I've had to replace the cold-start injector before cause it was leaking on mine causing a similar issue. You can play parts replacer and replace them both i don't think either one is highly expensive.
Old Apr 6, 2010 | 01:56 PM
  #52
Yeah I'm thinkin we're money this time. Unplugged the inj and no sputter just got done driving in rush hour traffic with no problems! You guys rule. If anything changes I'll be sure and update
Old Apr 6, 2010 | 03:49 PM
  #53
Ughhhh spoke to soon..... ideas...
Old Apr 6, 2010 | 05:12 PM
  #54
myyota's Avatar
When you first unplugged the cold start injector did it run good for a while ?. Try removing the cold start injector and cleaning it, if its like mine was it has a lot of carbon build up on it, also remove the throttle body and give it a good cleaning, and make sure all of the vacuum ports on the throttle body are clear and open. Make sure to buy a new throttle body gasket to replace the old one. When you clean the throttle body use carb cleaner, but don`t let it get into the TPS it might damage it. See what happens after that.
I don`t know if you got the email i sent you this morning, but i got the pictures of your 4Runner, it looks real clean, the old guy you got it from took good care of it.
Old Apr 6, 2010 | 05:39 PM
  #55
sounds like i have a good weekend project lol. thanks
Old Apr 7, 2010 | 03:41 AM
  #56
Question. What would cleaning the injector do. If I had it unhooked it shouldn't be functional right?
Old Apr 7, 2010 | 03:04 PM
  #57
84toyota4x4extcab's Avatar
i am having almost the same problem as you, except that it only happens to me if i drive at the same speed for a while and im at a loss as to whats going on but i am gunna try all this stuff and let you guys know if i figure it out
Old Apr 7, 2010 | 03:23 PM
  #58
Good luck! I decided to drive the ferrari today, this sputter thing is to much of a headache for city driving. I forgot how much fun it was to drive. Its been parked for about a month now..
Old Apr 7, 2010 | 03:44 PM
  #59
yotaman85's Avatar
this still has me scratching.. did you check the slosh thingy (technical term)
Old Apr 7, 2010 | 04:06 PM
  #60
Lol no I haven't yet I figured id drop the tank this weekend when I clean my tb.
