getting into gear issues
Old Jun 11, 2012 | 09:50 PM
bryy's Avatar
Okay to start I have a 1985 Toyota pickup extended cab EFI 4x4
Got the truck a little over a year ago and have since replaced a ton of parts due to previous owner neglect.
One of those parts being the master and slave clutch.
Now for the problem, in the very begging of the day or drive I should say and it seems on cooler days( I might be crazy) my truck shifts like butter threw all five gears and of course reverse if I use it.
Now what seems like on the hotter of days (90-100) or after driving in town for a while I have a hard time getting into my gears, especially first.
Now I am ashamed to say I replaced the master and slave with a auto zone units not asin
The clutch grabs great in my opinion and should only have about 20,000 on it.
I think I have a u- joint going out if that could matter. and it seems at high speeds and very rare in low speeds or not moving at all when I push in the clutch in gear or in neutral Instead of being smooth its ruff and gritty feeling.
if it helps with out fail this gritty feeling I can always feel when I push in the clutch in fourth gear and let it out in fifth, I feel it both ways.
Basically Im reaching out to see if anyone has any idea on what to replace first before I just go wild replacing parts.
Old Jun 12, 2012 | 06:24 AM
bryy's Avatar
oh and the bracket that holds the pedal is fine, The more I think about what parts to start replacing first the more none of this makes sense.
Old Jun 12, 2012 | 06:31 AM
James Woods's Avatar
Check the shifter seat bushing.
Old Jun 12, 2012 | 04:38 PM
bryy's Avatar
I replaced that with a marlin one a while back but for good measure I will check again. But how would I feel a shift bushing problem in my pedal?
Old Jun 15, 2012 | 10:15 AM
bryy's Avatar
still trying to figure this problem out might just start replacing the easy parts, and I just rebled the system about a month ago to try and fix the problem with no luck
Old Jun 15, 2012 | 10:29 AM
waskillywabbit's Avatar
Low fluid and nasty.
Clutch master rod needs adjusting.
Pedal assembly bracket fatigue.
Just ideas.
:wabbit2:
Old Jun 20, 2012 | 06:22 PM
bryy's Avatar
So I have replaced the u joints and check out a lot,narrowed it down to it being a drive line vibration, can this come from anywhere other then the drive shaft?
XtraCab
Apr 12, 2020 05:25 AM
mskalmus
May 28, 2017 07:51 AM
mengquis
Jul 13, 2015 10:39 AM
Poncho0206
Jul 10, 2015 06:21 PM
Jnkml
Jul 6, 2015 01:20 PM
