Fuel Pump Failure
Old May 19, 2008 | 05:45 AM
Ranski's Avatar
Fuel Pump Failure
My fuel pump recently stopped working. I get 10-11 volts at the pump when trying to start the truck but the pump doesn't come on.
Facts:
22re - 165k miles
When I pulled the fuel pump the filter attachment was not connected to the pump - it was lieing at the bottom of the tank.
Question 1:
Is there a reason why it won't come on other than because it is bad and needs to be replaced?
Question 2:
What can cause a pump to fail other than just being old? Basically I want to check/fix other issues so I don't burn up the new pump.
The following items checked out OK...
Main Relay
Circuit Opening Relay
Solenoid Resister
Cold Start injector
Installed new o2 sesor
Old May 19, 2008 | 06:11 AM
ahickman's Avatar
If the filter/screen was not intact, your pump most likely picked up rust/debris from the bottom of the tank. I would try applying 12V from battery directly to the pump and see if it torques/responds at all. If so, you may be able to flush the pump to dislodge the debris. Pumps are very expensive and it would be worth troubleshooting.
sandyota
Feb 4, 2021 11:16 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Fundy Rider
Jul 16, 2015 01:35 AM
Jonny246
Jul 12, 2015 04:51 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
