Front Turn signal Flashes Fast
Old Oct 21, 2007 | 08:39 PM
corvettelvr73's Avatar
Question Front Turn signal Flashes Fast
I got some regular amber trailer lights for the truck and I put them in the grille because I took my bumper off because I'm building one for it and when I got everything hooked up I turned the emergency flashers on and they flash like normal but if I turn the flashers on with the switch they flash as if the bulbs are burt out but everything still works front and rear. What could be the problem? Thanks
Old Oct 21, 2007 | 08:53 PM
Dare44's Avatar
mine did that after i replaced the front blinker assembly but then went back to normal after i took it apart and put it back together never did figure out why but it fixed it lol
Old Oct 21, 2007 | 09:04 PM
superjoe83's Avatar
its because the bulbs in the lights you bought don't draw enough power so the flasher thinks a bulb is out
Old Oct 22, 2007 | 07:43 AM
4Crawler's Avatar
Yep, different load on the flasher relay. Some options are to use a bulb with the same load as stock:
- http://www.4crawler.com/4x4/CheapTri...rnSignal.shtml
Or add a load resistor to the turn signals, or change to a soolid state flasher:
- http://www.superbrightleds.com/tail-brake-turn.html
Or modify the flahser to ignore the bulb load:
- http://www.pirate4x4.com/forum/showthread.php?t=463125
Old Oct 23, 2007 | 11:24 PM
XtraSlow_XtraCab's Avatar
Or leave it and be cool like the kids in their ricer Hondas!
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
oldirtydirt
Feb 23, 2020 09:30 AM
jasonty
41
Dec 23, 2018 01:00 PM
Suprarossa
Jul 6, 2015 05:21 AM
