noisy 22-RE
Old Oct 17, 2007 | 03:23 PM
4RunninFun's Avatar
noisy 22-RE
i've got an 85 4runner with the 22-RE and i know these engines are inherently noisy however from listening to another truck, and then listening to mine, mine is so much louder, i've adjusted the valves a couple times now with minimal improvement. i still hear tons of clatter. the timing chain is in good condition. so i'm pretty sure it's not that. looking for any suggestions... TIA!
Old Oct 18, 2007 | 02:35 PM
85toy's Avatar
i think mine is pretty loud too but i havnt got a chance to listen to anyone elses 22r
Old Oct 18, 2007 | 02:42 PM
bretthayes's Avatar
I had some valve chatter when i would start my rig.. it sounded like a diesel engine.. I discovered I had a few oil leaks and when I changed my oil pump during my timing chain repair, it went away.. Good luck..
Old Oct 18, 2007 | 09:45 PM
the_supernerd's Avatar
Over-tightening the valve cover bolts can cause a lot of valve noise. The bolts do not need to be tight. Try loosening them a little with the engine running and see if it gets quieter, but do not get them too loose or the valve cover will leak oil.
Old Oct 24, 2007 | 07:21 AM
Mr Maraki's Avatar
Have you checked your exhaust manifold? Bolts can loosen and back out, manifold itself can warp and cause dieseling sound with leak. On a cold motor, soak with penetrant, torque to spec. and then listen for leaks with a piece of hose.
tyzsdaddy
Jan 16, 2016 09:19 AM
dbollier123
Sep 29, 2015 05:23 PM
Obmi
Sep 16, 2015 02:13 PM
ac7822
Sep 11, 2015 08:49 AM
mreagen
Sep 8, 2015 03:46 PM
