BJ spacers pros/cons
Old Oct 25, 2007 | 08:47 AM
4x4YOTA's Avatar
ok I just purchased the BJ spacer from trdparts4u.com and was just wondering what the pros and cons are from the guys already running it and if you have pics of your front setup with the spacer
Old Oct 25, 2007 | 10:48 AM
sh0kk86's Avatar
well you get an inch or so to raise your front end, or relax your tbars, but why post in 84-85 section?
Old Oct 25, 2007 | 10:58 AM
Albert.G's Avatar
con is you have to get a realighment , pro is you got more flex in the fround
con is you have to trim your upper control arm... pro is you get more height
Old Oct 25, 2007 | 11:15 AM
bigredj87's Avatar
Correct me if I'm wrong, but by turning the t-bar nut you are just essentially rotating the bar. So your not making the actual bar have more tension in it. The bounciness associated with cranked t-bars is actually from most of the shock going in to the c/vs, and over extended shocks? I have only seen this posted on this site once before, and it makes perfect sense to me. My turning that little nut on the bottom of the truck, you are just changing the degree the bar is rotated not making the t-bar increase its spring rate. so bj-spacers would not effect your ride if you relax the t-bars, because the ride height is still the same, keeping the suspension geometry the same.
Old Oct 25, 2007 | 11:59 AM
AxleIke's Avatar
yes and no. You are only just turning the bar. The "bouncyness" is a result of a-arm to frame angles. Essentially, you are transferring more of the force of a bump directly to the frame, rather than being sprung by the torsion bar.
Conversely, by putting in a bj spacer and relaxing the bar, you get more force transfered to the tbar, and less to the frame.
I'll look around later, but there is a whole thread explaining it. It takes a while to type.
4x4YOTA
Aug 23, 2016 09:08 AM
89YodaRunner
Sep 30, 2015 02:18 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
4runnerFireman
Sep 29, 2015 06:24 AM
crash813
Sep 27, 2015 07:15 AM
