Front end sags
Old Jul 11, 2008 | 06:24 PM
meap's Avatar
Front end sags
Need some help in determining what to do. . . . I have a 84 22r 2wd and the front sags. The front end definetly sits lower then the back end. I think it looks like crap and I'm trying to figure out how to fix it. This is my commuter and "home improvement" truck.
I did some searches here and it seems like people have problems with the rears sagging but not so much the front. I replaced both front and rear shocks within the last few months. I replaced them with the cheapo Gabriels.
Any input? Thanks.
Old Jul 11, 2008 | 06:32 PM
4Crawler's Avatar
2WD should have torsion bars up front, cranking them up is one option or put in stifer bars:
- http://www.4x4wire.com/toyota/tech/torsion_bars/
Or put in a pair of ball joint spacers:
- http://www.4crawler.com/4x4/ForSale/...shtml#2WDor4WD
Old Jul 12, 2008 | 09:04 AM
meap's Avatar
thanks for the links. It looks like replacinig the torsion bars are the way to go
Old Jul 28, 2008 | 06:35 PM
meap's Avatar
I read some info on adjusting the torsion bars, I'm about 1 inch away from the bumpers bottoming out on the front. It looks like crap. How much can the torsion bar adjuster bolt be "cranked down" I have over 2" of thread already showing.
Also, does it matter that I installed Gabriel shocks instead of a higher end shock?
Old Jul 28, 2008 | 07:28 PM
20twinz's Avatar
SAS
Old Jul 29, 2008 | 04:03 PM
meap's Avatar
Old Jul 29, 2008 | 04:04 PM
fillsrunner4's Avatar
Originally Posted by 20twinz
SAS
Originally Posted by meap
SAS= Solid Axle Swap
Old Aug 4, 2008 | 05:12 PM
meap's Avatar
Hopefully someone here can help me. . . .please! I tried cranking down on the torsion bars and I got a couple of revolutions out but it may no difference in the ride height. Now i'm looking to replace the stock torsion bars and I can't find any. I called a Toyota dealer and they want $221 a peice! That is ridiculous! I called Old man EMU and they don't carry the 84' torsion bars and the guy thinks that the ones for the 86'-and up will work with my truck. Can anyone confirm this?
Does anyone have any input that may help?
Old Aug 4, 2008 | 08:30 PM
Geologist_01's Avatar
Can you provide pictures? That may help diagnose the problem, also check pick-a-part junkyard for some used Torsion bars (way cheaper than Dealership if you don't mind working a bit) if that is what you need. It can't hurt to look at mounts for suspension to see if anything is bent/broken elsewhere. Seems to me if you crank the bars it should do something to the ride height, maybe broken torsion bars? ( I'm not sure if that is likely but who knows) I have encountered all kinds of gremlins on mine and I kill 'em off one at a time.
Old Aug 6, 2008 | 05:10 AM
meap's Avatar
Here is a the side view. After adjusting the torsion bar it did make a difference but was very slight. The front height measure 8" from the top of the rim to the bottom of the wheel well. The back height measures 9-1/2" from the top of the rim to the bottom of the wheel well. So I'm looking to still get more lift out of the truck. Should I replace the torsion bars or ball joint spacers, or . . .?
Here is an underside view of the front drivers side. It is hard to see but the bumper is just over 1/2" away from bottoming out against the top bumper
Old Aug 7, 2008 | 03:37 AM
meap's Avatar
ttt .....
Old Aug 7, 2008 | 12:22 PM
Not sure but seems like your torsion bars are worn out, 1/2 inch clearance just seems too little. As for cost check around online (google), e-bay maybe even craigslist. If not pick-a-part yard are all generally cheaper than Dealer. Good luck. On a side note I did the timing chain on my 84 and had the head milled. The job wasn't hard but took a good day not including machining.
Old Aug 7, 2008 | 01:25 PM
forwardtocharis's Avatar
SAS
You do know it's a 2wd truck... a SAS would be ridiculous in general and impossible without a lot of suspension work...
Toyota used a lot of the same parts over and over again... there's a good chance the one from the 86 will fit, but I can't say for sure...
Swayaway carries it, not any cheaper-but it says it fits 84-97...
http://www.swayaway.com/TorsionBars.php
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
Massmayhem247
Jul 18, 2015 05:46 AM
Nickdigg
Jul 7, 2015 06:04 AM
Vargntucson
Jul 4, 2015 12:15 PM
