A few question on my 85 4runner
Old Mar 14, 2016 | 06:23 PM
soldiersnake's Avatar
I just saved this thing from a trailer park in coastal NC and brought it home this weekend and have been going through it. I have a few questions and pics below.
Is this the stock front leaf spring bracket?
Does this ecu look fried? I tested at like 162v with the ignition switched in the on position and the tester leads connecting the B+ and E1 with the harness connected.
The engine isn't getting fuel and I tested from the fuel pump to the circuit opening relay (COR) and they test good when jumped from a battery. The CEL isn't coming on and the COR isn't clicking with the diagnostic fuel jumper installed and the ignition turned on per the FSM.
In the last pic I am missing the black cap from that sensor. What is the name of the sensor and is it an issue that I am missing that cap?
I plan on getting her running, replace the springs/shocks/tires then tackle the rust.
Old Mar 22, 2016 | 07:30 AM
osv's Avatar
osv
https://www.yotatech.com/forums/f116...dle-up-141895/
i wouldn't worry about the missing black cap at this point, you have much bigger problems.
the ecu doesn't show any burned areas, nor any blown-out areas on the chips, right? put your nose against it, and see if anything smells burnt.
follow this guide to attempt fixing the fuel circuit, and to see if it's throwing any codes: http://www.4crawler.com/4x4/CheapTri...CheckConnector
i don't know about the spring mounting, my rig is heavily altered.
Old Mar 24, 2016 | 03:33 PM
D1rtyDan's Avatar
Looks like its the stock spring hanger, but if not why does it matter?
Old Apr 18, 2016 | 05:34 PM
reelal's Avatar
That cap is a filter to help keep dirt out of the vac. switching valve but is not necessary to the operation.
Vernsyota
Mar 5, 2016 04:59 PM
Dismalbogs
Feb 26, 2016 01:30 PM
catfish21
Feb 24, 2016 06:52 PM
Valvoman
Feb 20, 2016 07:53 AM
Calioutdoor
Feb 17, 2016 08:56 AM
