Fast Idle Cam Breaker
Old Jul 29, 2010 | 04:46 PM
84yotr's Avatar
Where does the FICB vacuum connect to? Every vacuum diagram ive looked at doesnt include it. This is on a california truck btw. Please help!! need to pass smog soon!! thank you
Old Jul 29, 2010 | 05:04 PM
xxxtreme22r's Avatar
you mean the choke breaker?
Old Jul 29, 2010 | 05:28 PM
84yotr's Avatar
no its on the other side of the carb. right above the idle adjustment
Old Jul 29, 2010 | 05:31 PM
you mean either the choke opener or idle up diaphragm then? no such thing as a Fast Idle Cam Breaker which is probably why you can't find it in the diagrams.
Old Jul 29, 2010 | 05:32 PM
Old Jul 29, 2010 | 05:34 PM
84yotr's Avatar
i found it in a couple diagrams. it just doesnt show where it connects. is the chock opener right above the idle adj screw? maybe theres just diffrerent names for the same part...
Old Jul 29, 2010 | 05:39 PM
84yotr's Avatar
ok the idle up diaphragm. but see even in those diagrams it doesnt show where the vacuum source is
Old Jul 29, 2010 | 06:13 PM
84yotr's Avatar
bump bump
Old Aug 2, 2010 | 06:23 PM
XtraSlow_XtraCab's Avatar
The choke breaker is not responsible for disengaging the choke, but it does creep it open a few degrees right after start up to minimize emissions (the truck "pollutes" more when the mixture is richened up).
If you downlaod the factory service manual via miy signature for a 1985 22R it should have that diagram. You really have to read closely because certain hoses might disappear behind another hose.
All I can recall (I have a Weber now) is that the choke opener plugges into one of the palstic Thermo-operated vacuum valves closest to the head... a little further forward of the opening diaphragm. The other tip of the existing vacuum valve must be supplied vacuum. So when the valves gets hot from the coolant beneath it, it allows vacuum to be connected to the diaphragm... thus BREAKING the FAST IDLE CAM.
Which is why you would be correct in naming it the FICB.
Old Aug 2, 2010 | 06:29 PM
Ok, I just looked at your bottom diagram. Its a BVSV valve... forgot what the B stands for but its B-something Vacuum-Switching-Valve. So it'll be one of the plastic valves with 3 ports and it looks like it shares that valve with the AAP (Auxilary Accelerator Pump). The AAp is a diaphragm on the front "driverside" of the carburetor. It's not a separate diaphragm... the actual housing is part of the carburetor. Anyway, track your hose from the AAP to it's plastic VSV and your FICB (choke opener) will plug into that valve as well.
Happy hunting.
Old Aug 2, 2010 | 06:36 PM
Ah, Hell.. here:
bigjstang
Jun 2, 2025 03:56 PM
Blamalam
Mar 12, 2022 07:34 AM
Dennisx2
Aug 10, 2015 06:48 AM
Fakayayou
Aug 9, 2015 12:47 AM
Dennisx2
Aug 4, 2015 01:26 PM
