engine surging
Old Oct 14, 2010 | 03:04 PM
joelgarcia707's Avatar
engine surging
just got done swapping in a newer 22re into my 85' pickup but have run into a problem. it idles fine but whenever you try to give it gas it surges as if it isnt getting any fuel. it sorta sounds like its just revving up. i just put in a new fuel pump recently and i also changed the fuel filter last week. fuel lines arent leaking either. this morning i noticed a pool of coolant underneath the truck. turns out the leak is coming from right underneath the throttle body where two coolant hoses are attached. would this cause my engine to perform this way? what other factors could cause this? thanks in advance for any help
Old Oct 14, 2010 | 07:55 PM
myyota's Avatar
Check and adjust the TPS if needed. Are you sure all of the vacuum lines are hooked up properly ?, especially those going to the EGR ?.
Old Oct 16, 2010 | 11:05 AM
yea the vacuum lines are all cherry. ive already adjusted the tps and it made the problem worse. il try getting a new one from a junkyard. someone also mentioned to me that it could be my knock sensor? i have no idea how that would affect it surging. any comments on that?
Old Oct 16, 2010 | 11:12 AM
xxxtreme22r's Avatar
when you swapped the motor did you swap in the newer ECU or did you keep the original one on the truck? or did you swap all the sensors from the old motor to the new one and keep the original ECU.
Old Oct 16, 2010 | 11:19 AM
i kept the old ecu and swapped everything over from the old engine to the new one.
Old Oct 16, 2010 | 11:28 AM
4Crawler's Avatar
Could cause that problem. The ECU coolant temp sensor determines idle speed to some degree so if there are air pockets (due to the leaking coolant), that sensor will see air/coolant/air/coolant/... and cause a surging idle.
Old Oct 16, 2010 | 07:10 PM
alright well that makes sense. i guess il start by fixin the coolant leak first and see if it helps. thanks
Old Oct 20, 2010 | 10:04 PM
just a follow up on the problem...i fixed the coolant leak and it didnt change anything. turned out to be a faulty knock sensor. everythings fixed and it runs cherry now. thanks again guys
smthwsn357
May 1, 2024 07:28 AM
icentropy
Sep 16, 2020 02:47 PM
RaginAsian91
Engine Swaps
Mar 30, 2019 09:17 AM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
razorman8669
Jul 12, 2015 12:13 PM
