engine problem
Old Mar 14, 2010 | 05:13 PM
Darknight84's Avatar
engine problem
I got some things that i need help to figure out whats wrong here we go
cranks but doesnt start, getting fuel to the carb , have a newer stock carb on there, no signs of a vacuum leak. and is timing maybe the issue as well I compression tested it and they where about 120- 135 psi so lower than normal though maybe its to low maybe need a rebuilt or what. Any ideas
Old Mar 16, 2010 | 04:38 PM
annoyingrob's Avatar
Does it have spark?
Old Mar 31, 2010 | 12:35 PM
No and there is black stuff at the bottom of the carb and in part of the intake
Old Mar 31, 2010 | 12:41 PM
Kiroshu's Avatar
Year/make/model? If no spark you need to look at your ignition system Check coil and ignitor(If applicable) For proper resistance, if its any bit out of spec its bad. Spark coming from coil? Check Distributor. Alt good? If does end up having spark try starting it with carb cleaner in the carbs intake.
Old Mar 31, 2010 | 12:44 PM
1984 toy 22r 4x4 ok ill try it thanks
Old Mar 31, 2010 | 12:56 PM
Kiroshu's Avatar
Any haynes manual will tell you how to test those items exact spec.
Old Mar 31, 2010 | 12:58 PM
Ok i think i have a Chilton will that work too
Old Mar 31, 2010 | 02:15 PM
Kiroshu's Avatar
Indeed
steve miller
Oct 10, 2015 01:40 AM
Yota.Jay
Jul 23, 2015 08:08 PM
Jnkml
Jul 6, 2015 01:20 PM
wilbertd
Jul 6, 2015 07:39 AM
