eating up connecting rod bearings
Old Mar 23, 2009 | 01:56 PM
frankentoyota's Avatar
what could cause my 22re to eat up connecting rod bearings.. like one every 15 km's.. its been 3 in 5 days. as i have not been able to work on it every day.. its getting really annoying to test drive it then ahve it blow another rod and have to fix it again.
Old Mar 23, 2009 | 04:45 PM
ok well i have it ripped apart now.. the rod bearings are good this time. my symptoms. knocking, loss of power(wont rev over 3000rpm), and metal shavings in oil.. what else could be doing this.. either something that causes rod bearings to fail or the last 2 just failed for no reason.. either or because i am lost
Old Mar 23, 2009 | 09:46 PM
any ideas?? the shavings are a copper color.. there is alot of them so it isnt just a bearing slowly wearing
Old Mar 24, 2009 | 06:45 PM
well i said it and pulled the motor today. got it all ripped apart. takin the crank to get machined tomorrow and going to order some new parts also tomorrow. pretty much everything that hasnt been replaced is gettin it. oil pump bearings seals and chain cover. if this dont fix it it a 350 would be cheaper
Old Mar 24, 2009 | 07:31 PM
Ed H.'s Avatar
low oil pressure, oil passages blocked maybe? check your drains in the head, oil pick up, pump, and other passages. dont just throw parts at this thing.
Old Mar 24, 2009 | 07:38 PM
oh i will be cleaning the whole block out while its apart. the pickup was fine. i think its about time for a new oil pump. and i think the head could use a good clean. shine up them valves and such so hopefully i get a little power back to turn some 35's one day
Old Apr 3, 2009 | 06:42 AM
CarbedNotch's Avatar
Did you check the clearance when you installed new rod bearings? Use a marking tape.
Make sure you put the right size bearings in there. Also if you like to use lots of RTV, you may have clogged an oil hole in the block.
Old Apr 4, 2009 | 12:04 AM
abecedarian's Avatar
for the most part, there's nothing copper in the engine other than the substrate within the rod and crank bearings.
if you keep chewing up bearings, the only logical cause is one or more blocked oil galleys, caused by either the residuals of one or more failed bearings or crap from a failed timing chain guide.
bigjstang
Jun 2, 2025 03:56 PM
4x4-runner
Dec 27, 2016 01:58 PM
JAmdor3
Aug 11, 2015 10:53 AM
Shaun Crystal Gomban
Aug 2, 2015 08:00 PM
