Drop down front hanger question.
Old Nov 20, 2007 | 04:47 PM
ydopen's Avatar
I'm planning on doing a drop down front hanger on my 85. What all will need to be extended besides shocks?
Old Nov 21, 2007 | 04:13 AM
WFO's Avatar
WFO
How far are you dropping it?
Old Nov 21, 2007 | 04:46 AM
ydopen's Avatar
Proably gonna cut off the tabs and do a 2 inch piece of box tubing then some 2 inch hanger/leafspring brackets off it. Not everything is set in stone yet.
Old Nov 21, 2007 | 05:17 AM
AxleIke's Avatar
Are you changing springs or anything else?
If not, you'll need to do something at the back (longer shackle, new shackle mount) to keep caster the same. Otherwise, you may have deathwobble issues.
Again, that is a possibility, not a certainty, check with more knowledgeable people. I recommend 4crawler...He also sells shims that would accomplish the same thing.
Old Nov 21, 2007 | 05:24 AM
ydopen's Avatar
I have 2 inch lift shackles on the front
Old Nov 21, 2007 | 05:39 AM
AxleIke's Avatar
well, then, no worries.
Old Nov 21, 2007 | 01:48 PM
ydopen's Avatar
What about extending the torque arm and sway bar bolts?
Old Nov 21, 2007 | 04:57 PM
ydopen's Avatar
Old Nov 25, 2007 | 03:22 PM
ydopen's Avatar
Old Nov 25, 2007 | 03:43 PM
4Crawler's Avatar
If still running stock steering, then use, use a longer bolt in the sway bar end link and easiest to do on the torque rod is to raise the bracket off the axle up to keep the rod ~level.
Old Nov 26, 2007 | 01:35 PM
ydopen's Avatar
Thanks awesome
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
coffey50
Jul 28, 2015 10:55 AM
rushw
Jul 18, 2015 01:46 PM
shisha1999
Jul 13, 2015 11:09 PM
