Old Feb 9, 2016, 10:13 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior Guides
Print Wikipost
Doing the SR-5 Gauge Cluster Swap... HOW TO with pictures.
Old Jan 8, 2009 | 09:57 AM
  #141
Windsor's Avatar
I watched over the guy's shoulder at Pep Boys when he punched it up... it said "Retail: $80, Sell for: $45".
For once, perhaps I should have gone to the stealer for the part.
Old Jan 8, 2009 | 10:06 AM
  #142
83's Avatar
83
It was around $50 from the dealership I think. Right now I just don't have an idiot light or gauge hooked up...not good, but until I got the gauge sending unit I just left the wire hanging. Now I've got the unit, and I'm going to run all the wires hopefully this weekend. In the pre-84 trucks, the oil & volt gauges are in a separate cluster, and if your truck didn't come with it from the factory (like mine), then it isn't wired for it, so need to cut off the plug-in's and splice some wires in to get mine working. Will be nice (and smart, finally) to have an oil gauge.
Old Feb 6, 2009 | 03:14 AM
  #143
trdtunedSR5's Avatar
Originally Posted by castrolsi
nothing. What you see in the photos is exactly what i did. Nothing any different.
Nothing additional, nothing changed. Pull the old one out, put the new one in.
Bam... Done.
The tach did come from a v6 truck though, so its off. I have to do a mod to
the tach to actually make it read the correct engine speed though. I'll do that
when i get that last amber bulb to go in the dash.
what do you have to do in order to get the tch working?
Old Feb 6, 2009 | 07:51 AM
  #144
4Crawler's Avatar
http://www.mindspring.com/~jayk3/toyota/tachmod.htm
Old Mar 13, 2009 | 06:31 PM
  #145
Secret237's Avatar
How do I remove the speedo needle ?? I want to up the mileage on my new cluster cause I don't want to go back in miles and the only way I can see to do that is to remove that darn needle and I just can't.
Old Mar 13, 2009 | 07:33 PM
  #146
Windsor's Avatar
Just grab the round base with your fingers and gently pull. It's a light press-fit.
Old Mar 13, 2009 | 07:34 PM
  #147
Windsor's Avatar
Originally Posted by Windsor
So perhaps the best advice would be to not let it (the gauge) sit there and cook with the engine not running (no oil pressure).
I'll swap the sender this weekend and report back, but every indication so far leads me to think that I haven't smoked anything yet.
FWIW, I put it off for a couple of months before I got it done (ended up using a Toyota factory part, stripped the threads on the aftermarket one).
It worked like a champ.
Old Mar 15, 2009 | 07:30 AM
  #148
Secret237's Avatar
I did try "Gently" pulling and it just won't come off. I was pulling harder than I really wanted to, still nothing.
I guess I'll just pull harder.
Thanks
Old Mar 15, 2009 | 07:35 AM
  #149
4Crawler's Avatar
See:
http://www.4x4wire.com/forums/showfl...Number=1147641
I have also used a pair of butter knives to lift up the needle on a VW speedo, the key is to lift evenly on both sides of the needle base.
Old Mar 15, 2009 | 07:43 AM
  #150
Secret237's Avatar
Ok, trying now
Originally Posted by 4Crawler
See:
Old Mar 15, 2009 | 07:47 AM
  #151
Secret237's Avatar
I cannot do it with my fingers alone, getting the knives
Originally Posted by Secret237
Ok, trying now
Old Mar 15, 2009 | 07:50 AM
  #152
4Crawler's Avatar
From the 4x4wire post:
"Then I pulled the needles off with a pair of spoons under the base of the needle"
Old Mar 15, 2009 | 08:05 AM
  #153
Secret237's Avatar
I am bending the metal shaft ... still not off
Old Mar 15, 2009 | 08:17 AM
  #154
Secret237's Avatar
Ok, got the black plastic cap off, broke it of course, but I can fix that, I can fix anything !!
Still got to get that needle off though. Looks like splines on the shaft
Old Mar 15, 2009 | 08:18 AM
  #155
Secret237's Avatar
I am going to try heat in a min. here
Old Mar 15, 2009 | 08:26 AM
  #156
Secret237's Avatar
Got it, no heat, but it was the shaft that came out of the gauge !! The plastic needle is still on the splined shaft !!
Just poped off and hit me in the head ... I was actually scared of bending my knives.
I've probably broken it, but IDK, I think all I need to do is glue it all back together !! Gauge still seems to work, there is now a sharp pin like thing sticking just above the surface, the needle shaft was over, or around.
But at least I'm there, Thanks
Geeze ... laugh
Old Mar 15, 2009 | 08:35 AM
  #157
Secret237's Avatar
I'm now advancing my odometer, still going to take a while, it's at 180,000 miles now and I have to take it up to just over 308,000 ... most people would turn it back !!!
I guess I'm a fool, it's just I put all those 308,000 miles on myself and I just don't want to go back.
Old Mar 15, 2009 | 08:38 AM
  #158
Secret237's Avatar
I figured if I had used a drill motor to run it up it would have taken over 80 days at 60 MPH 24/7 I would have bruned up my drill motor !!
This is easier ??
Laugh
Old Mar 15, 2009 | 08:43 AM
  #159
Secret237's Avatar
I'm now able to advance it at over 1 mile a second ( more like a mile every .75 sec. )
Still will take over 26 hours at this rate !!
Laugh, maybe I'll get faster
Old Mar 15, 2009 | 08:56 AM
  #160
Secret237's Avatar
I'm able to go about 125 miles a min. which is 7,500 MPH
Not bad for a 4 cly.
