Cheap replacement heads on ebay
Old Jun 1, 2015 | 08:11 PM
AnimalGuy's Avatar
Has anyone seen one or used one? My truck is needed some love in the head department and I cant have it down for more than a day. I was thinking of getting one of these then working the stock one at my leisure.
I used one of the timing chain cover kits to repair some of the hack work done by the Bakersfield Mensa Group I bought the truck from and that worked out pretty well.
Old Jun 2, 2015 | 01:26 PM
wyoming9's Avatar
Red face
If I needed a head I would buy one from Engine Builder I know there customer service is great if I have any problems.
Not saying Ebay is not great for some things .
Old Jun 2, 2015 | 02:26 PM
fierohink's Avatar
+1 for engnbldr. I bought 2 new 22re heads from him. The first stock, then years later a hot version with oversized stainless valves. Like Wyoming said, customer service is second to none. You can call and ask about torques, builds, cam degreeing, the weather in Stockholm, or cow futures and they have you covered.
Old Jun 8, 2015 | 06:30 PM
AnimalGuy's Avatar
Im going to go with a engine builder head since I picked up a side job with the foos, I was thinking of the unit with the oversized valves and a better cam to take better advantage of the LCE header. Im going to do the EGR valve at the same time.
I noticed he has a couple choices in cams, I do 99% street and 1% off road on job sites, I plan on getting new tires soon and they will be in the 30"-33" range for my 2 wheeler.
Anyone else do this swap and notice a little/big difference? Im fighting the urge to do a engine swap since that is where I usually jump right into.
Im going to call him later this week to see if he has one in stock ready to go.
Old Jun 8, 2015 | 08:51 PM
AnimalGuy's Avatar
And I am looking into new rockers and shafts while Im at it.
Old Jun 10, 2015 | 06:58 AM
FrankTorres's Avatar
I did this years ago (22re '86 4Runner) with over sized valves and RV cam; fresh block with over sized pistons. All EB parts.
I also had a LCE ceramic header. I was happy, it ran nice above 2000rpm, HP gains were there but minimal. If I were to do it again; and I have, I would keep everything stock (maybe oversize valves) or do a 3rz motor swap. Keeping it Toyota smooth and reliable.
Keep in mind that a more aggressive cam will not have smooth idle at 650 rpm. You should ask Ted about about your cam choice next time you call.
Good Luck
Old Jun 22, 2015 | 08:56 PM
AnimalGuy's Avatar
This has been put on hold. My side job went away when Dave broke his leg in Sweden.
bigjstang
Jun 2, 2025 03:56 PM
smiley52
Jul 11, 2015 05:16 AM
cyclist231
Jul 7, 2015 12:56 PM
colinmil
Jul 6, 2015 04:03 PM
wilbertd
Jul 6, 2015 07:39 AM
