Brand of Oil to use?
Old Oct 9, 2010 | 03:58 PM
  #101
JDS1992's Avatar
I run Valvoline Fully Synthetic..with a Napa Gold Filter..in my 3VZE
Old Oct 10, 2010 | 06:44 AM
  #102
1990yota-pickup's Avatar
i just changed my oil for 17 bucks i got 15/40 rotella oil 11.99 and filter was like 4 somthing.. no complaints for the engine yet...
Old Nov 27, 2010 | 07:09 PM
  #103
1985toy4x4's Avatar
I like Castrol 10w40 and a Motorcraft FL-1A filter.
Old Nov 27, 2010 | 08:47 PM
  #104
Teuf's Avatar
Valvoline syn blend 5/30, Toyota filter--------22re 276k miles
Old Dec 1, 2010 | 11:28 AM
  #105
AssYriaNrocKer's Avatar
Rotella T synthetic and stp filter but after reading up in this thread thinking about switching to wix
-RONI-
Old Dec 1, 2010 | 12:10 PM
  #106
Resto-noob's Avatar
That T6 is really good stuff.
Old Dec 1, 2010 | 07:11 PM
  #107
hell yeah it is and its always cheaper at walmart than any auto shop
-RONI-
Old Dec 7, 2010 | 01:16 PM
  #108
hnugen's Avatar
The key is to change your oil on time and often. Oil breakdown is gonna vary by brand but it doesnt matter much unless you are racing or live in extreme temperatures.
On my newer 4Runner, I use Purolator Premium with Castrol GTX every 2500 miles.
For everything else I drive, white Purolator filter and cheap oil plus changing it often works for me. Almost 200K miles on my beater Civic and the valvetrain is still silverish clean and very low emissions detected by the sniffer.
Old Dec 7, 2010 | 04:37 PM
  #109
peow130's Avatar
I usually use Castrol GTX. But pennzoil somethin or other was on sale, and i just spent most of my money on Tchain. and gaskets.. so i bought pennzoil lol
Old Jan 18, 2011 | 06:29 PM
  #110
richf's Avatar
I found a case of brad pen 20w50 in my shop and used it on my 2nd oil change since I replaced the front end of my engine and adjusted the valves numerous times. The 20w50 defiantly quieted down the engine and the partial synthetic hasn't produced any leaks. I had castrol HM 10w30 in it before I changed it.
Old Jan 18, 2011 | 06:47 PM
  #111
pushin glass's Avatar
Amsoil
Old Jan 19, 2011 | 02:08 PM
  #112
i bought a gallon of 15/40 rotella for 9 bucks a gallon at advanced auto parts...
and a frame extended tough guard filter.. its about due for anothe change soon..
maYBE IN THE SUMMER I WILL BUM IT IT UP TO 20/50 I KNOW THE 15/40 HAS quited donw alott of chatter..
Old Jan 19, 2011 | 02:21 PM
  #113
Teuf's Avatar
Ditch the fram get a yota filter........ Get a #90915-yzzd3 its a little bigger than the reg size.
Old Jan 19, 2011 | 03:00 PM
  #114
its fine with the one thats on there...
Old Jan 19, 2011 | 03:06 PM
  #115
PismoJoe's Avatar
Mobil, non synthetic
Mark, Fram's check valves often fail. These valves keep oil in the filter at all times, so at startup you have oil pressure. If this fails, you're dry cranking. TOYOTA FILTERS FTW!!!
90915-yzzd1/or d3 is the most common.
Old Jan 19, 2011 | 03:16 PM
  #116
every oil filter will hold 2 ounces of oil after it has been drained.. thats why the have to have a hole punched in them to drain for the epa. or crushed...
Old Jan 19, 2011 | 03:19 PM
  #117
kevtek's Avatar
Yea, frams are pretty bad. Aside from the check valve and the rest of the cheap parts inside, they drop pressure in a lot of motors. Put one on an old VW camper and the oil light will never turn off. That said, I'm not going to the dealer for an oil filter... Generic dino oil and wix filter.
Old Jan 23, 2011 | 09:13 PM
  #118
Jaden84's Avatar
From what I have heard, walmart supertech oil and mobil 1 is the top rated oil and the penzoil is one of the worst, I use mobil 1.
Old Jan 23, 2011 | 09:39 PM
  #119
streetstomper's Avatar
I'm with you on that one, all I have ever run in my vehicles is Castrol.....NO knocks ticks or smoke.
Old Jan 25, 2011 | 02:44 PM
  #120
well i hear to tell ya.. i havent had any issue with running rotella 15/40 in my truck with a frame tough guard or extreme tough guard filter...
it actually sounded alot quiter after the 15/40..
