brakelights?
Old Feb 20, 2009 | 01:37 PM
84toyota4x4extcab's Avatar
brakelights?
Okay so my brake lights dont work i know its in the wiring somewhere but i cant figure out where it is... so if someone has had this problem please help haha
Old Feb 20, 2009 | 01:43 PM
scuba's Avatar
You checked your fuses then ?
Old Feb 20, 2009 | 02:19 PM
yep all fuses are good
Old Feb 22, 2009 | 11:03 AM
TrikeKid's Avatar
Check the grounds and all the connections at the lights themselves. I had one of the terminals break off at the light bucket on mine. Little solder and she was good as new.
Old Feb 24, 2009 | 09:24 PM
mosser84toyota's Avatar
did you check the switch.
Old Feb 25, 2009 | 01:05 AM
kjishikawa's Avatar
Yeah brake switch. I just replaced mine today.
Old Dec 22, 2013 | 12:49 PM
mudmusher's Avatar
I have a 1990 pickup extened cab with the same issues. The fuses are good, my mechanic fiddles with the fusebox and it's fine, for a while. It's like it works loose. It's fine when I get home, but when I go out the next day or so, the idiot light is lit again.
Old Dec 24, 2013 | 04:25 AM
rokblok's Avatar
If it's just the "brake" light on the instrument cluster, either fluid level/sensor, or E-brake handle switch adjustment. That would be my guess...
Seventynineyotar
Jan 2, 2017 06:52 PM
Punchy
Apr 5, 2014 04:58 PM
ovrrdrive
Apr 4, 2008 01:39 AM
4RunnerFever
Jan 20, 2004 07:20 AM
