FS[PacSouthWest]: Interior and exterior from 92 4R SR5
Grey color
Headliner, Great shape no kinks.
The sunroof liner ring.
All door trims
Door floor trims.
Side panels set, This is the two rear sides w/compartment doors, One rear over the rear window, two middle between the doors, two windshield column and two kick panels.
Rear speaker boxes w/amps.
Carpet, Front and rear set (needs cleaning of course) in good shape, The normal gas peddle heel wear spot in front drivers and a small gash in the rear that hides with the rear seats up.
Tailgate carpet cover, Good shape.
Door panel set ( all four door)
Rear seats sets with head rest, They are immaculate.
Dash pad, has cracks
Dash panels, One under steer column, gauge cluster bezel (black).
Visor set.
Mirror rearview w/map lights.
Glove box.
Seat belt front set.
Seat belt rear set.
Center column compartment w/rear heater assemble (broken compartment latch)
Parking brake lever.
Steering wheel w/horn button, Rough shape.
Wiring harness set, dash and fuse box all the way back to the tailgate, This is a manual trans dash harness and is missing 2 plugs, Heater blower and clutch bypass but the wiring still there.
Rear chrome fender trim, Both sides, Not in the best of shape.
Rear window trim (black).
Rear airfoil, aluminum, No third brakelight hole, halfass sandblast job otherwise black.
Roof rack rails w/ cargo cage mounts only.
Mirror set, Sides, Electric, Chrome from PU.
Rear bumper (yup, dents), Chrome and black plastic top.
Trailer hitch HD, 500 lbs tongue wt, Tight fit under bumper and undercarriage spare.
Rear fender liner set.
Widows (rear sides) set, factory tint.
Also have in green.
5 doors set $120
w/ windows, hinges, harness, locks and motors, seals, I have the key and will throw in a matching ignition switch, (rear window defog does not work).
Fuel door (keyless)
Hood $30, great shape very oxidized paint, w/cowl vent plate.
I may have missed some nick-nack but ask.
Sets sold together.
Make offers.
No ship, pick up in 91765 only.
Lorne
please txt
626-675-2013
All door trims
Door floor trims.
Visor set.
Glove box.
Seat belt rear set.
Also have in green.
5 doors set $120
Fuel door (keyless)
Sets sold together.
Make offers.
Lorne
please txt
626-675-2013
The reason I don't is that the cost of shipping pretty much doubles the price if not more.
Its just not worth the trouble since 90 percent of the items wont fit in a USPS "If it fits it ships" box or being lowballed to a point of giving away.
Yeah, like roark said, shipping option is crucial... I'd be all over three different items if you could and if the price was appropriate.
**edit** That said, I'm looking for front seat belts and the maplight/rear-view mirror setup. I know those items would all fit into a large flat-rate box, just in case you change your mind, and I'm at 98107.
83yotastockR
11
Nov 10, 2015 06:54 AM
smilen724
13
Nov 8, 2015 04:11 PM
sonorn67
Sep 19, 2015 05:39 PM
reallynotamechanic
Sep 11, 2015 11:52 AM
