Brake upgrade
Old Apr 28, 2011 | 06:57 PM
CAPTDASH's Avatar
Brake upgrade
I finally got around to starting my brake upgrade on my 85 4Runner. The thing is, I did the last thing I was going to do first. I put on a dual diaphram brake booster. All I can say is WOW, I have freakin unbelieveable brakes now.
The pedal is real soft, but it doesn't take any pressure to get the front brakes to lock up. I adjusted up the back brakes and it felt better. I got to get one of those proportioning valves now and even up the braking.
Holy crap I can't wait to get the new rotors, calipers, master cyliner, etc. I am going to put 94 4Runner V6 front brake components on the front end. If you haven't changed out the old single diaphram booster, that is a great upgrade.
Anyone have any idea how I can get a firmer pedal. I extended the pedal clamp and jam nut all the way out. I don't know what else to do but get used to it.
Old May 5, 2011 | 12:07 AM
myyota's Avatar
I have the same set up on my 86 4Runner and it works great and the peddle is not soft. You do not need to add a proportioning valve. Did you bleed the rear load sensing proportioning valve ?, or you might have a bad master cylinder. When i did the swap on my 86 4Runner i used a dual diaphragm brake booster and master cylinder from a 92-93 4Runner. If you used the stock 85 master cylinder with the larger brake booster, then thats your problem, you need to use the master cylinder for the larger brake booster because its larger and moves more brake fluid.
Old May 5, 2011 | 05:52 AM
CAPTDASH's Avatar
Yeah I am using the smaller MC. I just unbolted the MC and slid the BB out and the larger one in. I plan on getting a larger MC, so maybe that will solve the soft pedal. Thanks
Old May 16, 2011 | 04:58 AM
CAPTDASH's Avatar
Today is the day for me. I will be swapping out the old 85 front brake hardware for some fresher 94 V6 4Runner hardware. That should help me stop a little better. Pics to be posted later.
Old May 16, 2011 | 07:13 AM
Outsane's Avatar
done yet?
Old May 16, 2011 | 07:22 AM
CAPTDASH's Avatar
Originally Posted by Outsane
done yet?
LOL, nope. I had to unload firewood, four wheeler and hunting equipment from weekend hunting trip. It will be later today. My goal is to get at least one side done. I never get in a hurry. Everything will be thoroughly cleaned as I put it back together. I will be threading the steering knuckles for 1/2 inch bolts to replace the metric ones(that frequently strip out) that bolt down the calipers.
I will keep you posted as I get it done, with pics.
Old May 16, 2011 | 10:27 AM
Outsane's Avatar
well i need something to look at while waiting at work
Old May 16, 2011 | 06:10 PM
CAPTDASH's Avatar
Outsane, my apologies for not getting anything done. It has been storming/raining off & on all evening. I will try to make some progress tomorrow evening. I will have you some "eye candy" for you to check out Wednesday. How about that?
Old May 16, 2011 | 06:14 PM
Swimmerboy2112's Avatar
Very nice, i am installing T-100 calipers, rotors and pads along with a 1" bore master cylinder and a dual diaphragm brake booster over the weekend!
Old May 16, 2011 | 08:03 PM
Outsane's Avatar
Looking forward to it
Old May 17, 2011 | 04:56 PM
CAPTDASH's Avatar
All I can say is well ˟˟˟˟˟. I don't know if the rotors I got are simply the wrong ones in the box, the salesman sold me the wrong ones, or either the 94 4Runner rotors won't work. I can't imagine these being the right rotors. The lug holes are very small. The tips of the M12X1.5 studs won't even go thru the holes in these rotors. Does anyone know if Toyota has smaller studs on the 94 & up 4Runners?
I got rotors and 2 studs ready to head to parts store in the morning. I knew I was making too good a time for it to be true. Taking 2 studs cause I fubarred one of them. Making sure I get the right stud. I will keep you guys posted.
Outsane, I am taking plenty of pics, but so far all I can show you is boxes with the wrong parts. Thanks ADVANCE.
Old May 18, 2011 | 07:32 PM
CAPTDASH's Avatar
Well the damnest thing has come up. None of the rotors that ADVANCE or Oreilly's sells other than the ones for an 85, will work. The rotors both parts stores carry have the wrong sized stud holes in them. The tips of the M12X1.5 studs will not go through the holes in the rotors. We looked at 4Runners, Truck, tacomas, tundras, t100's, the works.
Someone please tell me what am I missing on the rotors.
Old May 18, 2011 | 08:37 PM
Outsane's Avatar
I think I used Landcruiser rotors..
Old May 18, 2011 | 09:14 PM
skoti89's Avatar
what kind of brake booster did you use? a junk yard and new brand?
Old May 19, 2011 | 03:35 AM
CAPTDASH's Avatar
Skoti, it came off of a 90 model 2 wheel drive TACO in a nearby salvage yard.
Old May 19, 2011 | 03:39 AM
CAPTDASH's Avatar
Yep I think that is what I am going to have to do. I think I will go back down a couple years on the calipers too. The gap for the rotor to roll through on the 94 4Runner is noticeably wider than on the calipers for 93 4Runner.
I still don't understand the situation with the studs for a 94 not fitting into the rotor at all. That just doesn't make sense.
Old Jun 2, 2011 | 12:39 PM
cazador's Avatar
Does anyone know if a 93 V6 pickup brake booster will work or does it have to be a
4Runner.
Old Jun 2, 2011 | 06:30 PM
CAPTDASH's Avatar
4Runner.
I used a 90 model 2 wheel drive Tacoma. It had the small 26.75 inch circumference that is exactly the same circumference as the stock single diaphram on 85 and older trucks/4Runners.
Old Jun 3, 2011 | 07:22 PM
ccannon222's Avatar
86-95 rotors will not work on 81-85 hubs. The 86-95 rotors bolt to the back of the IFS Hub where the 81-85 rotors are pressed on with the wheel studs. What you need is FJ60 rotors. These press on just like the SA rotors. Then you can use 95 V6 4R calipers and pads. Along with these pads you will need 1" bore MC and a Dual Diaphram Brake Booster.
Chris
Old Jun 3, 2011 | 07:44 PM
CAPTDASH's Avatar
Chris
Yep I got the 87 LC rotors. Going to stick with the 95 V6 4Runner calipers. I have had the dual diaprham booster installed for awhile. I am getting the 94 4Runner V6 MC as it is only 65 bucks at AutoZone and they have it on the shelf. It is 1" bore as well. Maybe I will get this all together this weekend. i bought me a newer 4 Runner and have not been concerned with getting it done.
