Brake pressure/pedal problems
Old Jul 13, 2009 | 09:44 PM
seanmearse's Avatar
So, As everyone may or may not know, i now own an 84 pickup with a 22R. During the day, as in on my way to work, on my way home for lunch, on the way back to work from lunch, the brakes operate very firmly and responsive with minimal pedal travel. On my way home from work, after 9 pm, the pedal goes about two inches off of the floor, just like if the pads were almost to, but not quite, the end of their life. I have checked the pads and shoes, drums and rotors. Everything is clean and leak free, and also moves as it should. I just cant figure it out at all. Any help would be awesome! (and yes i went through a bunch of brake posts, and nothing matches my issue).
Old Jul 14, 2009 | 06:54 AM
seanmearse's Avatar
Anyone have any thoughts on this?
Old Jul 14, 2009 | 07:19 AM
taconasty's Avatar
mine gets pretty spongy after a while. bleed the fronts and see if that helps. i need to do the same.
Old Jul 14, 2009 | 07:21 AM
seanmearse's Avatar
thats the wierd thing though, they are are fine all day, then once the sun goes down, they suck.
Old Jul 14, 2009 | 10:14 AM
kodayota's Avatar
maybe your brake solar collector is going bad. it should be able to absorb enough power to make it through the night.
vaccum leaks in the booster? worn master could let fluid pass the seals?
Old Jul 14, 2009 | 10:23 AM
seanmearse's Avatar
No leaks at all though. well, im going to go out and get her ready for primer.
Old Jul 14, 2009 | 12:56 PM
desertcamper67's Avatar
Never heard of that one before. Bleed them. Adjust the rears. My guess is master cyl.
Old Jul 14, 2009 | 03:06 PM
oldgold3vze's Avatar
Make sure you're bleeding the Load Sensing Proportioning Valve (LSPV). My brakes have never felt better after bleeding it. Or, go one step above and replace the stock one with an adjustable valve for $40.
Old Jul 14, 2009 | 03:10 PM
seanmearse's Avatar
dude, i honestly forgot to check that little guy! well, off i go into the heat.
Old Jul 14, 2009 | 06:16 PM
Aenema's Avatar
I have been having the same problem with my 85.. my guess was the master cyl, but my dad seems to think the old Autozone pads i bought are the problem.
But now im going to check into the LSPV
Old Jul 15, 2009 | 08:18 AM
seanmearse's Avatar
That didnt work, im just going to give it a few days till the 87 sells, then just re-build the whole brake systems. I guess you could call it peace of mind. and these front springs! ahhhhhhh! Its like a low rider! It has its issues, but i love this truck.
Old Jul 15, 2009 | 09:10 AM
Aenema's Avatar
Haha yeah, my front springs are so wore out they are inverted >.<
Old Jul 15, 2009 | 06:30 PM
seanmearse's Avatar
Its the pits for sure. I just need to get some new springs on order, have to sell the 87 first though, i think i will create a post for it tonight. oh, i will also put up picks of how the 84 is looking after about 15 cans of paint. give me a sec and i will go take some.
Old Jul 15, 2009 | 06:55 PM
seanmearse's Avatar
Here is a few before sanding.
Now, back to the brake issue.
Old Jul 15, 2009 | 09:21 PM
Aenema's Avatar
Heh, Glad to see im not the only one that slams my seetbelt in the door too.
But i have narrowed my problem down to 4 things (possibly related to yours)
1. Bad pads
2. Im by-passing my master cyl. making my pedal feel spongy
3. My brake fluid is boiling in my master cyl. because its summer
4. Grease from my knuckles is getting onto my rotors making them slippery.
Old Jul 15, 2009 | 09:44 PM
seanmearse's Avatar
Hmmm. The problem im having is that the pedal is normal during the daylight, as soon as the sun goes down it goes down, to the floor that is. but it still stops. its just impossible to get used to.
Old Jul 17, 2009 | 09:28 AM
Aenema's Avatar
When you let up and push back down, does the pressure come back? or does it go back to the floor?
I found out that my knuckle's are leaking grease and flinging that grease onto my rotors. Im gonna have to get a knuckle rebuild kit from Marlin Crawler
Old Jul 17, 2009 | 09:20 PM
seanmearse's Avatar
You aint the only one. Its a mess down there!
Eggslinger
Jun 8, 2019 03:32 PM
jasonty
41
Dec 23, 2018 01:00 PM
skoti89
Sep 11, 2015 07:46 AM
Johntom240
7
Jul 13, 2015 12:18 AM
Jnkml
Jul 6, 2015 01:20 PM
