any recommendation's for a rear disc swap
Old Aug 2, 2013 | 11:44 PM
Stetson_md's Avatar
I'm looking for some info bout how to go about doing a disc swap for a daily driver(what kinda parts i should use ,how I should do the ebrake, if I should do it at all, ect)
Only reason I'm considering the rear disc swap is I think I might come out cheaper or just slightly more then rebuilding my drum brakes. Either way it'll be a while before I get to working on the brakes
My current rear brakes are shot in the A there locked up the lspv is rusted thru and most of the brake parts on the axle are missing messed up , once I get it somewhat restored I plan to dailyish drive it
Old Aug 3, 2013 | 04:10 AM
wyoming9's Avatar
Red face
I can`t see how it will be cheaper.
You can weld and do the Fab work to hang the caliper brackets.
Then maybe you plan to just swap in a Disc Brake 4Runner complete rear axle put spring pads on install under your Truck.
This would also solve the E-brake question.
Now I have not measured the new axles not sure if this is workable endeavor .
In any case lots of fab work no doubt someone markets a kit
Another option is the transfer case brake
I have seen lots of threads do some research figure out what will work best for you
Old Aug 3, 2013 | 10:05 AM
Stetson_md's Avatar
That rear end swap idea sounds even better to be honest what year runners have disc rears?
Old Aug 3, 2013 | 10:48 AM
bob200587's Avatar
Have you asked front range off road?
Old Aug 3, 2013 | 10:49 AM
gennro's Avatar
this http://www.pirate4x4.com/forum/axles...-made-usa.html
Old Aug 3, 2013 | 03:20 PM
donomite49's Avatar
i have a trail gear rear disc conversion for over three and a half years with no complaints so far.
skye off road also makes a kit that uses a different GM caliper from a caddy i think, with a cable e-brake, something about it made it difficult iirc. other than having to source calipers yourself.
all pro makes a transfer case mounted e-brake that i am going with when i get around to it.
i also have a willwood proportioning valve to install, again when i get around to it.
you can also upgrade to v6 front calipers and roters. oops never mind the solid axle is harder to upgrade the front calipers i think. just looked back to see what rig you have.
don't forget to upgrade to a 1" bore master cylinder too when you go rear disc's.
Old Aug 3, 2013 | 07:19 PM
rokblok's Avatar
V6 calipers/FJ60 rotors/1" bore master/ dual diaghram booster are all bolt on for a solid axle. You will also need minimal 1.25" spacers on the front, to clear the calipers. I opted for the 1.5" spacers since I have the 3" wider (than stock front solid axle) rear diff from an IFS Runner.
Old Aug 3, 2013 | 08:30 PM
wyoming9's Avatar
Red face
He is looking to do the rear disc brakes
Old Aug 4, 2013 | 12:26 AM
Stetson_md's Avatar
What do yall think of the low range off road economy rear disc kit (made by trail tough ) with a tcase brake or line locks That way its all 100% yota? Would that setup work for a street truck or is it off road only? Cause I kinda like the idea of having 4 matching calipers and 4 matching rotors and 8 matching pads
http://www.lowrangeoffroad.com/index...onomy-kit.html I know my parts guy has a good lspv and the 1 inch master idk bout a dual diaphragm booster tho
Old Aug 4, 2013 | 02:13 AM
'85 Yota's Avatar
Looking forward to see how your swap comes eventually. Im highly likely going to to a rear disk swap to in the future!
Old Aug 4, 2013 | 04:42 AM
rokblok's Avatar
But Wyo, he ^^ started it... I know we were talking about rear upgrades, but Dono said "the front calipers", so I was clarifying for that portion.
I'm going to go work on my Toy so Wyo can't pick on me anymore....
mskalmus
May 28, 2017 07:51 AM
jerusry
Oct 19, 2015 05:28 PM
icentropy
Jul 9, 2015 02:12 PM
Nickdigg
Jul 7, 2015 06:04 AM
toyoda8488
Jul 5, 2015 10:18 PM
